Old 06-17-2010, 09:33 AM   #1
oldford2
oldford2's Avatar
Default serial number on a 46
Everytime someone is looking for the serial number they are told to look on the left side of the frame just before the front crossmember and they generally find it. I have scrubbed mine down to the bare metal and can see nothing there. Is there a second place they may have used? This is just more of a curiosity thing than real need.
oldford2 is offline   Reply With Quote
Old 06-17-2010, 09:46 AM   #2
Steves46
Steves46's Avatar
Default Re: serial number on a 46
I think another area is on top of the bell housing.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 06-17-2010, 10:20 AM   #3
Joe KCMO
Joe KCMO's Avatar
I know for other years, the number is on three places on the frame. The front is the easiest to get to.
Joe KCMO is offline   Reply With Quote
Old 06-17-2010, 11:04 AM   #4
Vic Piano
Vic Piano's Avatar
John, The number could be on the frame rail anywhere from the cowl to the radiator, depending on where it was built, who was doing the stamping and what time of day it was... Like so many other Ford anomalies, there really is no right answer. Our '47 rag top has the vin # on the left front frame rail just as you described. I had a '46 TuDor that had the vin # closer to the steering box on the frame rail.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 06-17-2010, 11:23 AM   #5
chopnchaneled
Mine is on the top of the frame just in front of where the shock mount
would bolt on.
chopnchaneled is offline   Reply With Quote
Old 06-17-2010, 12:23 PM   #6
blown49
blown49's Avatar
oldford2, Is your picture taken from the top or the side?
Jim
Visit my Blown '49 Merc website @ http://www.blown49.com
blown49 is offline   Reply With Quote
Old 06-17-2010, 01:33 PM   #7
ford1
lol , depending on whether or not the number stamper was pissed or not you can find it any where stated, if its not where its supposed to be look right at the cowl it maybe just under the cowl, if so you will have to lift the body to see it
ford1 is offline   Reply With Quote
Old 06-17-2010, 01:33 PM   #8
oldford2
oldford2's Avatar
from the top
Old 06-17-2010, 01:38 PM   #9
Tinker
Tinker's Avatar
Vic nailed it.
I have a 42' that is stamped just to the left of where you have cleaned off. It curves around the front cross member on the frame.
Old 06-17-2010, 02:53 PM   #10
oldford2
oldford2's Avatar
Default Re: serial number on a 46- Tinker got it
Tinker got it! Found my VIN right where the front crossmember is riveted to the frame (and it matches the title!). Looks the guy stamping it used the edge of the crossmember to guide his stamps so a nice neat job. Thanks to all that offered help. John
Old 06-17-2010, 04:20 PM   #11
~~Walts37~~
~~Walts37~~'s Avatar
I could not find mine that looked just like your picture till someone told me to pour some tap water on the area . Like magic it did appear. My 2 cents ~~Walts37~~
~~Walts37~~ is offline   Reply With Quote
