02-15-2018, 01:55 PM | #1 |
Sealed beam headlight 40 ford
I cannot find a reasonable cost source for the stock 6volt head light on a 40 ford. I think, Bob Drake has them for 25 dollars each. Looking for the non halogen ones.
Will the 6006H Halogen sealed beams work with stock wiring? They seem to be more common. |
02-15-2018, 03:50 PM | #2 |
Re: Sealed beam headlight 40 ford
I personally wouldn't use halogen lights in my 6v cars. They can draw a lot of current and I would hate to tax my wiring or headlight or dimmer switch. Someone posted here that there are newer halogen lights that don't draw so much current but I am not taking that chance. Many use a relay with them to prevent too much current going through the light switch.
02-15-2018, 04:23 PM | #3 |
deuce makes a very good point.
02-15-2018, 04:25 PM | #4 |
There are several listings for Wagner 6006 sealed beams on eBay that are cheaper than BD, e.g., https://www.ebay.com/itm/7-6-Volt-Seal-Beam-Headlamp-Bulb-Ford-1940-55-/142669282640
02-15-2018, 07:18 PM | #5 | |
I switched to halogens in my A 15 years ago, changed nothing except the bulbs, i found that I could reduce the charge rate and have brighter light ---with the stock generator |
02-15-2018, 07:24 PM | #6 |
02-15-2018, 07:30 PM | #7 |
The modern 6 volt headlight bulbs have the alignment tits on them that will interfere with the headlight bezel on the 40 . They can be ground off if you use lots of patience and plenty of water to keep them cool. Of course use an air grinder and don't get aggressive.
02-15-2018, 09:32 PM | #8 |
I have nos 6 volt bulbs with no aiming tits for sale.
02-16-2018, 09:37 AM | #9 |
Stock headlight bulbs are ford script on the glass and have a metal backing is that the bulbs your looking for?
Wanted Roadster Pick up thank you COLOR] |
02-16-2018, 08:05 PM | #10 |
sounds good. What are you asking for them and are they new or used?
02-16-2018, 08:52 PM | #11 |
Gezer.....Barnfind08 is a regular here on FordBarn. He runs a side business selling quality NOS Ford parts. Imagine being able to buy brand new eighty-year-old FORD stuff. He will not answer your question on the forum in respect for the forum rules. All you need to do is send a PM (personal message) to barnfind08. He'll get right back to ya. DD
02-16-2018, 08:57 PM | #12 |
If you have never done a PM, go to the name over his avatar and click on it. There will be a drop down menu. The second option is for PMs.
02-17-2018, 01:25 PM | #13 |
If you want to have good 6v headlights on a Ford you have to install a relay in the headlight system. The use of a relay will supply full voltage to the headlights, while only requiring minimum draw through the switch.
When I put sealed beam head lights on my '36 in 1952, I installed a relay in the system, mounting same on the fender splash pan, my head lights have always worked great..
Bill.... 36 5 win cpe |
02-17-2018, 02:47 PM | #14 |
1940 ford all ready has a head light relay
02-17-2018, 03:14 PM | #15 |
02-17-2018, 07:00 PM | #16 |
02-17-2018, 07:45 PM | #17 |
JSeery s right, that thing is a circuit breaker not a relay. The current comes from the circuit breaker to the switch, then to the headlights via the dimmer. IF there is a short it breaks the circuit to avoid a wiring fire. I have seen them cut in and out repeatedly.
02-18-2018, 07:53 AM | #18 |
call it what you want the man asked for a stock 6v seal beam for a 40 ford. 40 fords came with seal beams.no mod needed.
02-18-2018, 10:41 AM | #19 |
Relay suggestion was in relation to halogen lights only.
02-18-2018, 12:15 PM | #20 |
A close look at my Avatar will reveal that the headlights on my '36 are 1940 Chevy headlight pods fitted to the fenders in lieu of the stock Ford lights. I harvested the entire system off of a '40 Chevy, including the wiring, switch and relay. I don't recall Ford's having relays in the headlight system in the early '40's, where-as GM did.
I believe it is a well known fact that 6v systems have very high resistance, that is why larger wire is used, compared to a 12v system. Supplying the power to the headlights via a relay makes a big difference as to how bright the lights are.
