Old 01-30-2018, 03:42 PM   #1
russcochiolo
russcochiolo's Avatar
Default Ford Sedan Delivery vs Gibbons conversion
A friend recently acquired a Gibbons Sedan Delivery conversion on a '29 Tudor. How much longer is the original Ford Sedan Delivery. I know wheel bases are the same. I'm interested in the body length. Where can I look for dimensioned drawings? Thanks
russcochiolo is offline   Reply With Quote
Old 01-30-2018, 03:58 PM   #2
Licensed to kill
Licensed to kill's Avatar
Default Re: Ford Sedan Delivery vs Gibbons conversion
It's my understanding that the sedan deliveries (28-29) are the same basic body as a tudor just with the rear door and panelled in quarter windows. The longer body came about with the Deluxe delivery (30-31)
Licensed to kill is offline   Reply With Quote
Old 01-30-2018, 04:04 PM   #3
jb-ob
Russ,
The 1929 Tudor and Deluxe Delivery have the same bodies except in the upper panel stampings. The Tudor rear window is shorter than the Delivery advertising panel and the Delivery side rain gutters are longer.
Illustration with measurements for the Tudor, p.42 'Ford Model A Restoration Manual A-1' by FoMoCo 1955.
JB
jb-ob is offline   Reply With Quote
Old 01-30-2018, 05:58 PM   #4
d.
there is a great side by side photo of an original 28-29 tudor body and an original 28-29 sedan delivery body in a MAFCA Restorer letter to the editor in the mid 70's I recall.
The photo has the 2 bodies standing vertically on the firewall, and clearly shows that the sedan delivery has a much longer side window and a much shorter rear section than the tudor body.
Someone with the MAFCA digital archive CD could dig this out and reprint it here to show the difference.
I have no idea which version of the 28-29 Gibbon copied.
Just for reference, in 1932 Ford only made the tudor body in 1 configuration and then either filled the rear side windows with glass for the tudor or steel inserts for the sedan delivery.
d. is offline   Reply With Quote
Old 01-30-2018, 11:23 PM   #5
daveymc29
daveymc29's Avatar
I just traded a tudor sedan that I had converted to become a deluxe delivery by buying the correct upper metal panels, rear center section and door. They fit perfectly with the exception of the rain gutters on the delivery being longer than the tudor. I even found a stock tool box from a high point restoration delivery that had been sold to a rodder who had no use for the tool box. When I first started the project an acquaintance in the Auburn area was doing the same thing I was, but with a Gibbons kit. They look very much identical to the untrained eye that cant see plastic and know it from steel. I couldn't tell without wrapping on a panel with my knuckle and getting the dull thud sound. Other than that the Gibbons looked great.
daveymc29 is offline   Reply With Quote
Old 01-31-2018, 09:32 AM   #6
russcochiolo
Thanks for the responses so far. Here's a photo of a delivery off the net. What I'm asking is how much longer is this body than the Tudor/Gibbons conversion? It apears to about 14" behind the wheel well. Is there a site somewhere that has dimensioned drawings of the Sedan Delivery? I've found dimensions for other A models. Russ
File Type: jpg 578017_10151793305868642_731028877_n.jpg (10.1 KB, 80 views)
Old 01-31-2018, 10:00 AM   #7
katy
katy's Avatar
Is the sedan delivery same as a panel delivery? Or a panel truck?
Old 01-31-2018, 10:29 AM   #8
Licensed to kill
I could easily measure mine if you like. The panels are leaning up against the wall but it's a 31 and I think they are different than a 28-29. It seems to me, IIRC, I was told that my 31 is 8" longer than a sedan.
Old 01-31-2018, 11:01 AM   #9
russcochiolo
#7 I think that the terms are synonymous. #8 A measurement from the center of the wheel well to the bottom of the rearmost body will be appreciated. Thanks
Old 01-31-2018, 11:32 AM   #10
Licensed to kill
I will get you that measurement this morning. I don't think the terms are synonymous. A sedan delivery and a panel delivery are two different animals. The panel delivery is larger and more square with a higher roof
Old 01-31-2018, 11:35 AM   #11
Licensed to kill
Panel delivery https://www.pinterest.ca/pin/208291551492596767/
Old 01-31-2018, 12:09 PM   #12
Licensed to kill
30.5 inches from the centre of the wheel opening (in line with the top fender mounting bolt) and the rear most edge of the panel (next to the rear door jamb)
Old 01-31-2018, 01:12 PM   #13
russcochiolo
Thank you #12, That's the info I was searching for.
Old 01-31-2018, 01:23 PM   #14
russcochiolo
I just checked MODEL A FORD GARAGE and there is no Sedan Delivery listed. "Sedan Delivery" must be a local use of a later term......my bad! Listed were, "Panel Delivery; Deluxe Delivery; Town Car Delivery; Special Delivery and Postal Delivery". Thanks to all respondents.
Old 02-01-2018, 02:06 AM   #15
CHuDWah
CHuDWah's Avatar
No...
...and no
Left to right, Panel Delivery, Deluxe Delivery (official Ford terminology but commonly called sedan delivery), Town Car Delivery, Special Delivery, and Postal Delivery
CHuDWah is offline   Reply With Quote
Old 02-01-2018, 09:19 AM   #16
russcochiolo
Thanks for the photos #15. The A my friend has looks to be the Deluxe Delivery. I think that he will be pleased with the info. His is steel, so probably not a Gibbons conversion. PO told him that the conversion was to a Tudor. It already has been modified with juice brakes and an Iron Duke/'39 box. It came with Moss Green paint in a can. He will be happy to see the photo with white walls. I think all his cars have them. The finished product will look stock to the casual observer.
Old 02-01-2018, 06:22 PM   #17
daveymc29
daveymc29's Avatar
Russcociolo
You'll find that to be a keen car when done. That's the one I spoke of yesterday. It is all steel and everything on the car from the belt line down is tudor, with the modifications. Everything above the belt line on the body west of the windshield is de luxe delivery, original steel. I was just too old and tired to finish it up.
Old 02-01-2018, 09:09 PM   #18
Mike/Nebraska
can you still get those delivery kits from anyone?
Mike/Nebraska is offline   Reply With Quote
Old 02-02-2018, 04:21 AM   #19
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Everything WEST of the windshield!!!---Now, that's FUNNIE!!!--LOL
Is that viewing it from the DRIVERS' SEAT????? Or using the rear view mirror??---Are you facing CAYOTE MOUNTAIN? The SHADOWS "might" CONFUSE you????
Bill Confused?????
"THE ASSISTANT GURU OF STUFF"
Old 02-02-2018, 05:14 PM   #20
CHuDWah
CHuDWah's Avatar
Supposedly JPM Hot Rods has the Gibbons molds - dunno if they're producing the delivery kit. You might try contacting them:
http://www.jpmhotrods.com/
