07-25-2022, 11:12 AM | #1 |
4spd OD on a flathead in a 1932 Ford. Pt.3. Custom clutch disc.
In this video I make some progress with the conversion of a Volvo M410 transmission with overdrive to fit in my 1932 Ford. The one stipulation is that I don't want to cut the original K member. After lots of head scratching I realise the clutch disc I had isn't going to work. That opened up an opportunity for an alternative solution. Have a look and see what I came up with.
https://youtu.be/2p96M5qPAN0 |
07-25-2022, 03:48 PM | #2 |
Re: 4spd OD on a flathead in a 1932 Ford. Pt.3. Custom clutch disc.
Very interesting project Mart! I'm sure enjoying this! Thanks for sharing.
07-25-2022, 05:40 PM | #3 |
Hay Mart: One issue that is worth checking out is will there be enough room for the throw-out bearing sleeve (before it hits the clutch disc) and will the throw-out bearing have enough "throw" to properly disengage the clutch - or will things be too tight with the extended clutch disc setup you've created?
07-26-2022, 03:33 AM | #4 |
I have investigated clutch release travel and all seems well.
Thanks for the interest and thoughtful comments. |
07-26-2022, 06:44 AM | #5 |
