03-29-2022, 04:34 PM | #1 |
Fire Hazard
What's the main cause/reason of a fire with the A's?
03-29-2022, 04:36 PM | #2 |
Re: Fire Hazard
Gas soaked air filter. Leaky carb.
03-29-2022, 04:41 PM | #3 |
Re: Fire Hazard
Second is the starter rod coming off and hitting the battery connection on top of the starter.
03-29-2022, 06:13 PM | #4 |
Re: Fire Hazard
Leaking gas gauge and sparking ignition switch.
03-29-2022, 08:07 PM | #5 |
Re: Fire Hazard
Non fused wiring shorting to ground
03-29-2022, 09:11 PM | #6 |
Re: Fire Hazard
Dave / Lincoln Nebraska |
03-29-2022, 10:28 PM | #7 |
Re: Fire Hazard
stupidity
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
03-30-2022, 12:53 AM | #8 |
Re: Fire Hazard
Oxygen, heat, fuel.
03-30-2022, 09:56 AM | #9 |
Re: Fire Hazard
After reading, on here I think, about an AA burning up due to electrical short, I've been learning to pull the fuse on the starter when I'm done. Even new cars catch fire, so a 90 year old one is maybe a little more prone.
03-30-2022, 10:33 AM | #10 |
Re: Fire Hazard
My CCPU doesn't have a "fuse on the starter", but it does have a "battery disconnect" switch.
03-30-2022, 11:23 AM | #11 |
Re: Fire Hazard
Gas soaked paper air filter (due to leaky carburetor and leaky shut off valve) + backfire:
Brad in Maryland |
04-01-2022, 09:55 AM | #12 |
Re: Fire Hazard
This is why you firmly grab your air filter, and throw it as far away from your car as possible...an air maze is different, so it don't count
04-01-2022, 10:01 AM | #13 |
Re: Fire Hazard
i normally ad a fire extinguisher to the cars i work on, this photo has just reminded me that i need to buy one for my car. TODAY!
04-02-2022, 08:53 AM | #14 |
Re: Fire Hazard
Fuel + oxygen + ignition source + sustained reaction = fire. And while the gory details of the "most common" situations are helpful, its the situation (however uncommon) that you miss that creates the fire.
04-02-2022, 09:37 AM | #15 |
Re: Fire Hazard
And the best fuel source sits basically in your lap.. Ford faced a number of legal issues with the cowl mounted fuel tank..you can imagine what todays lawyers would do with it..I can see the TV ads now “If you had a 28 to 31 ford, contact Lowball and Lynch today, you could be entitled to financial compensation”
04-02-2022, 10:26 AM | #16 |
Re: Fire Hazard
All cars should carry a fire extinguisher. The battery disconnect will eliminate an electrical short when parked and could save a car if a short develops when driving. Both should be accessible.
The fire extinguisher should be rated for electrical, gasoline, and other combustibles. The standard extinguishers are bulky. I carry this one: https://elementfire.com/ which is smaller and attaches to the underside of the tank with a magnet.
04-02-2022, 11:10 AM | #17 |
Re: Fire Hazard
nkaminar, Which model did you buy? The E50 or E100? The magnetic clip shown for $15. as well or did you make your own?
One thing I like about these extinguishers is they "effectively puts out fires without the mess, toxicity, or maintenance associated with a traditional extinguisher." |
04-02-2022, 11:33 AM | #18 |
Re: Fire Hazard
I bought the E50 and the clip. I have the E50 in my modern truck, the travel trailer, and the kitchen too. The E100 lasts longer (100 seconds) so if you are very concerned about fire that would be the one to get. It is more expensive, but a fire is going to be a lot more expensive.
I had one on by sail boat too but I also had 6 of the traditional fire extinguishers and a old halogen extinguisher in the engine compartment. The original owner of the boat had a fire pump driven by the main engine. He sailed the boat around the world. When you are out in the middle of the ocean you want to be sure to be able to put out a fire.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 04-02-2022 at 11:39 AM. |
04-03-2022, 09:53 AM | #19 |
Re: Fire Hazard
At least there would be lots of water available.
04-03-2022, 10:54 AM | #20 |
Re: Fire Hazard
It didn't seem to work very well for the electric VWs on the boat last month.
