08-03-2022, 03:29 PM | #1 |
79 granada engine noise
79 granada with engine rebuild new bearings rings and lifters TWICE ..Engine startedout with what sounded like lifters so thinking i may have got bad ones replaced those to no avail. it now sounds like no oil up top but after removing top pan i find lots of oil at an idle and oil pressure is very good.. Now the only thing i did not replace was the cam and bearings as they seemed as new..It is not rod or mains i am sure but what sounded like a slight lifter noise when started is getting worse and i can now hear it in the car so getting a bit scaryIt is the 4.1 in line 6 by the way..So i will sign off and hope some specialist sees this and gets back to me...Thanks in advance..
08-03-2022, 04:41 PM | #2 | |
Re: 79 granada engine noise
Valve lash is determined by push-rod length in this hydraulic valve-train design. There is a STD length push-rod and 0.20 O/S and U/S lengths. Varying length lifters and push-rods were also used in this series.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
08-03-2022, 09:37 PM | #3 | |
08-04-2022, 12:21 PM | #4 |
All push rods were meticulusly put back in place where removed from..timing chain well within specks new tappet rod and tappets seem tight seems like lots of oil up top so a head scratcher..Also head was donewith new guides seals and valves were needed so???
08-04-2022, 08:12 PM | #5 | |
It is one of three things (IMO), incorrect valve lash, insufficient oil pressure and/or a bad camshaft. We went through all of this a few months ago didn't we?
08-04-2022, 10:38 PM | #6 |
08-05-2022, 05:05 AM | #7 |
With the tappet cover off and the engine at idle, see if the push rods are rotating..
08-05-2022, 06:21 AM | #8 |
Flat tappet cam. did you use the zink additive mixed with the oil on start up and run at proper speed for a length of time? New lifters on an old cam can wipe out the cam lobes, and if it's getting louder, that sounds like the problem.
08-05-2022, 08:06 AM | #9 | |
The only thing I know to do at this point is to verify cam lobe lift and lash. How did he rebuild an engine without a manual?
08-05-2022, 09:11 AM | #10 |
08-06-2022, 07:13 AM | #11 |
ALL INFO WAS FROM A HAYNES MANUAL AND THE MECHANICAL EXPERIRENCE OVER THE YEARS..tHE MANUAL WAS FOR THAT CAR..
08-06-2022, 08:41 AM | #12 |
It may be time to drain the oil and cut open the oil filter. Run a magnet through the oil and see what sticks to it. Read up on how to dissect an oil filter and what to look for.
08-06-2022, 08:58 AM | #13 |
That's fine. There was no section on setting up the valve-train after the rebuild?
08-06-2022, 08:56 PM | #14 |
Can anyone tell me the correct valve lash for this engie as i can not find it anywhere???
08-06-2022, 09:00 PM | #15 |
The only thing I could do is copy the pages from the WSM and mail them to you as my copier has a case of no-go.
