08-03-2022, 12:55 PM | #1 |
eezibleed brake bleeder
I have a quick question here. I bought an Eezibleed Brake Bleed kit & had to make an adapter out of the master cylinder cap. The cap has a vent hole, should this hole be plugged? I'm thinking it should be or fluid may run all over. Thanks.
08-03-2022, 12:55 PM | #2 |
Re: eezibleed brake bleeder
Yes, the cap vent needs to be plugged.
Used mine today. Worked great on the Sedan. |
08-03-2022, 01:09 PM | #3 |
Thanks Mart.
08-03-2022, 08:25 PM | #4 |
"Speed Bleeders" are cheaper and easy to use.
08-06-2022, 06:26 PM | #5 |
Hi Mart, what does your master cylinder adapter cap look like? I haven't had much luck with my modification. It tends to weep when I use it. Thanks.
08-07-2022, 08:47 AM | #6 |
