03-17-2012, 08:10 PM | #1 |
33-34 pickup seat question
My 34 truck cab has a nice back spring but has the individual biscuit cushions on the bottom that are separate. Is there a one piece bottom cushion that will fit well on the gas tank ?
thanks for any info. Larry
03-18-2012, 02:41 AM | #2 |
Re: 33-34 pickup seat question
I think you could use the small truck springs. The split cushions are large truck type. Macs in NY carry the full ones ..
03-18-2012, 04:37 AM | #3 |
The split seat bottom is allow for filling the gas rank that was the seat base on at least some 32 pick ups.
03-18-2012, 06:23 AM | #4 |
My 34 pickup has the gas tank at the rear of the bed, not under the seat.
Gary. |
03-18-2012, 08:30 AM | #5 |
My 34 pu has the split cushions and I believe they are original, have seen several others the same way.
03-18-2012, 08:50 AM | #6 |
www.fordcollector.com |
03-18-2012, 10:23 AM | #7 |
As far as I know the pickups had the gas tanks under the bed while the big trucks had the gas tank under the seat. So the pickups would've had a one piece seat while the big trucks would've had the split seat.
Red |
03-18-2012, 10:46 AM | #8 |
It is a big truck cab and has the gas tank located under the seat. I have moved the tank to the rear frame (I am using a car frame). I have cut the top out of the gas tank to use as a seat riser inside the cab like the regular 1/2 ton. I am asking if the one piece seat springs are available or if a 34-35 bottom cushion will work. I do not have access to one to measure it. I would purchase a 1/2 ton seat riser and bottom cushion if available ?
thanks for all the replies, I appreciate the help. Also although I havn't figured out how to change my signature, I have found a nice set of mercury hubcaps thanks to the generosity of one of the Ford Barn members.
03-18-2012, 11:04 AM | #9 |
The 33-34 solid bottom spring should work fine. Yours sits on the actual gas tank, or is there a seat riser around the tank as well? Heres a picture of my pickup...
Thee Inland Emperors |
03-18-2012, 11:07 AM | #10 |
One piece bottom seat cushion for a '34 pickup should work. Check with LeBaron Bonney, Macs, or other suppliers and I'm sure you'll find the seat spring or complete bottom upholstered cushion.
03-18-2012, 11:09 AM | #11 |
Sorry Chris...I type S L O W !
03-18-2012, 11:39 AM | #12 |
My 1934 Ford P/U has the fuel tank between the frame members at the rear also. The P/U fuel tank is the original one that came with the P/U when is was bought brand new at the Michigan, North Dakota dealership. I bought the P/U from Vern Hanesalo who is the original owner according to the paperwork that came with the P/U. The fuel tank is between the frame rails at the rear of the vehicle.
03-18-2012, 02:20 PM | #13 |
Get a new one piece and it will fit the gas tank - and more comfortable.
03-21-2012, 06:49 PM | #14 |
my 2 cents my gas tank is in the rear of the truck on my 34.Rick
03-22-2012, 10:05 PM | #15 |
Gas tank location: 32 Pickup is under the seat
33-34 Pickup is behind the rear crossmember ( same as the car) 32-34 Big truck is under the seat the 34 cab in my avatar came from a dump truck. I use the original tank as a seat stand. |
03-23-2012, 06:04 AM | #16 |
ILL 2nd that .
03-23-2012, 09:04 PM | #17 |
I see some of the hot rodders cut the tank out for a storage bin. Have not done that as I hate to ruin a good tank, but my seat is hinged at the front.
03-24-2012, 07:54 AM | #18 |
Here are pic's of gas tank & seat in my 34 pickup, hope this helps.
Gary. |
03-28-2012, 09:57 AM | #19 |
31 chevy what is that swith under the seat for.Rick
03-28-2012, 10:40 AM | #20 |
Looks like a battery disconnect switch to me, good place to put it. Nice job on your restoration.
