Old 05-12-2014, 07:24 PM   #1
moonshine runner
moonshine runner's Avatar
Default Bob Drake Water Pumps
Well,
I got my new Bob Drake water pumps today. Ordered them Sunday May 4th, and they arrived to my door via UPS this afternoon.
Will be installing them this week. Can't wait to see how these improved pumps work!
Kevin
"Failure is simply the opportunity to begin again, this time more intelligently".
Henry Ford.
moonshine runner is offline   Reply With Quote
Old 05-13-2014, 01:30 AM   #2
IGotIt
Default Re: Bob Drake Water Pumps
I have a set in my 48 and they seem to be working well. Temps went down and they've been doing good for over a year now
IGotIt is offline   Reply With Quote
Old 05-13-2014, 09:18 AM   #3
Admiral
Admiral's Avatar
My engine builder installed these pumps on my 59L. I haven't run them yet so I can't comment with personal experience but he said they're really good, and at 100 bucks for a pair it's hard to go wrong.
Admiral is offline   Reply With Quote
Old 05-13-2014, 10:11 AM   #4
36 flathead
I have these on my 50 merc motor for 2 years. no problems. runs very cool.
36 flathead is offline   Reply With Quote
Old 05-13-2014, 10:28 AM   #5
prpmmp
Had small leaks at the bottom of the pumps!! Filed the surface flat at the bottom bolt hole!! OK now!! Pete
prpmmp is offline   Reply With Quote
Old 05-14-2014, 12:02 AM   #6
Graeme / New Zealand
Graeme / New Zealand's Avatar
I've just put them on mine and am very happy with them and it does run cooler. Mask up the back and give them a blast of paint. I was told by a few that the black paint on them doesn't last
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 05-14-2014, 01:33 AM   #7
Talkwrench
Talkwrench's Avatar
I haven't got 12 months on mine yet , however no probs doin' fine.
Don't forget to use stainless steel bolts + anti seize.. depending on which car you have good luck at getting the lower hoses on! ; o )
Old 05-14-2014, 02:56 AM   #8
Trick for getting the lower hoses on. Soak them in boiling water for a few minutes. This makes them more pliable to manouvre them into position and allows you to bend them a bit.
GB
Old 05-14-2014, 06:06 PM   #9
moonshine runner
Thanks for all the replies!!
Kevin
Henry Ford.
Old 05-14-2014, 10:16 PM   #10
Bassman/NZ
Bassman/NZ's Avatar
Happy with mine.
Bassman/NZ is offline   Reply With Quote
Old 05-14-2014, 10:51 PM   #11
allford
Smile Re: Bob Drake Water Pumps
I installed mine about one year ago and i love them..Motor runs cooler
allford is offline   Reply With Quote
Old 05-15-2014, 09:47 PM   #12
moonshine runner
Got started on the job tonight. Got the right one off. Not real sure, but looks like a PO may have used a wrong gasket that blocked some of the water flow off.
I removed the old gasket and once I pulled the bottom part off, coolant ran out so that could have been causing some cooling issues before.
Kevin
Henry Ford.
Old 05-15-2014, 10:26 PM   #13
40cpe
40cpe's Avatar
There is a small hole right beside the bolt inside the pump at the lower hose. This hole can become clogged with sediment and not drain the block just behind the pump. Maybe you disturbed the sediment blockage for the water to drain out. I would make sure that recess behind the small hole behind the pump is clean before reinstalling the pumps.
