Old 02-05-2019, 06:01 PM   #1
Rustyscrap
Angry SLOW starter
The starter in my '31 PU gave up the ghost after 40+ years of faithful service (just totally dead). I attempted an overhaul: cleaned up commutator, new bushings and brushes. It passes all the field continuity tests and the armature spins free, but when I jumper test it on the garage floor the armature just barely turns. Anyone have any advice on what to try next?
Rustyscrap is offline   Reply With Quote
Old 02-05-2019, 06:32 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: SLOW starter
Just my 2 cents worth here:
1) Maybe not getting good current flow through the brushes
2) bent shaft
3) bad ground
I am NO electrical guru and welcome to the Barn!
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-05-2019, 08:50 PM   #3
Synchro909
Synchro909's Avatar
What is your power supply when doing this? Is it capable of maintaining 6 volts when the starter is connected?
Old 02-06-2019, 09:58 AM   #4
Gary WA
Gary WA's Avatar
Ground-clean shinny bright and tight!! Out of car??? Getting good voltage ditto#3
www.whidbeymodelaclub.com
Old 02-06-2019, 10:14 AM   #5
katy
katy's Avatar
I would suspect that the brushes and/or the commutator are contaminated w/oil.
Are the brushes still long enough to get good spring pressure against the commutator?
Clean the commutator off w/a good degreaser and try a new set of brushes.
Old 02-06-2019, 12:58 PM   #6
Badpuppy
If the starter switch is mounted during test, that may be the cause.
https://www.fordbarn.com/forum/showp...29&postcount=4
Old 02-06-2019, 04:07 PM   #7
Werner
Werner's Avatar
Hello,
I do not know if I understand the problem correctly.
When starting the cold engine with thick 25W-50 oil, I measure a current flow of about 150 amperes, the voltage drops to <5 volts. Both are normal.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 02-07-2019, 10:30 AM   #8
katy
katy's Avatar
I believe his problem is the starter itself, not the cold weather.
Old 02-07-2019, 10:56 AM   #9
Smooth_One
Smooth_One's Avatar
Ground issue? Mine was spinning very slow when testing and i added a ground from the frame to the trans bell housing and much better. But if your testing on the floor then maybe you have a starter issue. Volt meters are a great way to narrow down the problem.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 02-07-2019, 11:19 AM   #10
Patrick L.
Patrick L.'s Avatar
By 'garage floor' I'm assuming you mean the starter is not in the car. Did you test the commutator ? Its an easy test with a continuity meter but you may have to take the armature to a shop for a growler test.
Old 02-07-2019, 11:52 AM   #11
Russ/40
Russ/40's Avatar
Been there done that! Brushes in the wrong holders! I had the same exact problem. Corrected the brush locations, problem solved.
Old 02-07-2019, 06:42 PM   #12
Big hammer
I had mine apart way to many times, I found it wasn't the starter, It Was My Modern Car that I was jump start/ spinning the A starter.
get a bigger hammer tap done
Old 02-08-2019, 03:46 PM   #13
woofa.express
woofa.express's Avatar
I wrote this in "mini starter" this morning and is quite applicable to this thread. It is copied and pasted. gary.
I had my Tourer (parked behind the ute in the picture below) converted to 12V some time back but not the starter. Each time I cranked I shuddered at the severe impact. I have busted 2 armature shafts so I purchased new field coils. had fitted and started so well. ONCE.
Disassembled and packed the bendix so it wouldn't jam. Again it started so well. ONCE. At present I am awaiting the rebuilding of my starter with a 5/8 shaft and new bendix by the guru Synchro and I reckon he will rebuild like new.
HOWEVER when I purchased the field coil I was unaware of the new light weight starter. I had one demonstrated to me at the Murray Bridge meet and it was a beauty.
From my experience don't mess with your original starter, unless you are a concourse entrant, just buy a light weight.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 03-15-2019, 10:45 AM   #14
Rustyscrap
Solved the slow starter. It was caused by a cold solder job on the soldered brushes. These connections are difficult. Requires a soldering iron of 200 watts. New wires have to be "tinned" properly before connecting to the lugs. Had I to do it over again I wouldn't have even replaced the solder connected brushes. I think proper operation is all about the condition of the commutator.
Old 03-15-2019, 10:56 AM   #15
Anteek29
Anteek29's Avatar
Hooray...thanks for letting us know you fixed the problem!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 03-15-2019, 11:06 AM   #16
Terry, NJ
Terry, NJ's Avatar
Another aspect of this problem may be a poor ground. The best way I know of getting a starter to turn faster is to ground it directly to the battery. The ground path through a lot of old , rusty, riveted joints is not good. Use a modern 12v cable and connect to the same bolt as where the primary ground strap connects. Put a large hole connection (not a battery connecter) the other end. Connect that end to a 3/8 starter bolt and go turn the key and press the starter. It should be able to turn faster and start quicker.
Terry
Old 03-15-2019, 11:07 AM   #17
Purdy Swoft
Purdy Swoft's Avatar
If the brass-bronze field brushes are so badly worn that they must be replaced , I usually just pick a better core to overhaul . The field brushes usually last a lifetime or more . It is just too easy to ruin a good starter if you don't have the proper tools and experience to replace the field brushes . The ground brushes attach with screws and will usually suffice . The carbon ground brushes are the ones that wear the quickest and most . .
