04-02-2020, 08:32 PM | #1 |
47 frame without the front six cyl mounts
Well I just noticed my 47 tonner with a v8 doesn't have the forward mounts for the six cyl option. My whole cummins swap was built to drop into this setting and for the first time I see this rig only has the holes for the v8. The motor mount hole is 1 1/4" so I can bore it with a hole saw but wtf?
What's strange is it has the forward radiator mounts for the six in the front cross member, but not the 1 1/4" dia diagonal motor mounts.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 04-02-2020 at 08:38 PM. |
04-02-2020, 09:01 PM | #2 | |
Re: 47 frame without the front six cyl mounts
That ain't nothin' that a real hot rodder couldn't take care of in a half hour or so! DD |
04-02-2020, 11:00 PM | #3 |
I take that as a challenge..... I can have those two holes bored through there in 15 minutes! Just thought it was so odd that of all the 46 and 47 trucks I have here, maybe seven of them, this is the ONLY one that doesn't have the six cyl mounts drilled..(I never even looked). And the only one that actually needs them. Ironic that I spent many extra hours engineering an engine conversion package that does not require even one small hole in the frame or sheet metal and then this. I will drill them tomorrow, and proceed as planned. Your's truly, a Real Hotrodder. (if a 210 cu in, 120 hp 6 cyl oilburner measures up to that status)....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
04-05-2020, 09:11 PM | #4 |
Six minutes to do the both of 'em.... The two hole mounts ate a shaped a bit differently than the 4 hole, but I have it covered. They are all 1 1/4"
04-05-2020, 10:13 PM | #5 |
I just knew that you were up to the challenge. That's going to be an interesting rig! DD
04-05-2020, 10:35 PM | #6 |
