04-12-2011, 09:34 AM | #1 |
Cracked block
My friend's engine has a crack in the block (see photo). There was an old repair, but the crack found its way around it. This is cylinder #3.
The engine is bored 0.060" over. Can it be sleeved and rebored to 0.060"? This is a good running engine and he would like to salvage it if he can. Can it be fixed? Coolant had been seeping into #3 and this is what he found. Pressurizing the cylinder with an air compressor made bubbles in the radiator. |
04-12-2011, 10:08 AM | #2 |
Re: Cracked block
The crack can be pinned on the deck and a sleeve installed and bored with no problem. This crack looks simular to the crack that was in the engine for my rdstr pu. Be sure to have it magnafluxed as it likely goes all of the way to the valve and possibly could extend into the valve port. Rod
04-12-2011, 10:37 AM | #3 |
Re: Cracked block
That is exactly what mine looked like and I did just what Rowdy said.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
04-12-2011, 10:42 AM | #4 |
Re: Cracked block
In my opinion Why gamble with crack repairs, magnaflux, etc. I would pull the pan and check , crank shaft , worn lobes on the camshaft, etc etc. you might come to the conclusion it's cheaper and safer to go for a complete overhaul. No gambles then and trouble free touring.
04-12-2011, 11:07 AM | #5 | |
Re: Cracked block
04-12-2011, 11:40 AM | #6 |
Re: Cracked block
04-13-2011, 06:21 AM | #7 | |
Re: Cracked block
04-13-2011, 07:41 AM | #8 | |
Re: Cracked block
Yes you can put in a sleeve and bore it .060 over, but fix the pinning job first. |
04-13-2011, 09:10 AM | #9 |
Re: Cracked block
Thanks again for your suggestions. I will relay to my friend.
