04-23-2019, 06:45 PM | #1 |
Dual MC for 41
Well finally decided on this MC for the 41. Not much room down there or any dual without remote fluid pots.
https://flic.kr/p/2fyQPbS Have a corvette one now but hard to check the fluid level. https://flic.kr/p/TvdHiy http://nolimit.net/products#!/Remote...tegory=8625919
41 woodie https://41fordwoodie.weebly.com/ Last edited by mrtexas; 04-23-2019 at 06:50 PM. |
04-23-2019, 10:24 PM | #2 |
Re: Dual MC for 41
I mounted a dual Ford Torino, fitting towards the center of the car, to my stock '41 pedal. Used an adapter from Chassis Engineering. Spaces the M/C back a couple inches, 3 bolt to 2 bolt. Had to lengthen the pedal to M/C rod.Worked good.
04-23-2019, 10:39 PM | #3 |
Re: Dual MC for 41
The safety feature of a dual master cylinder only activates at the bottom of pedal travel, maybe a half inch from the floor. If the pedal bottoms out on the floor before the master cylinder reaches the end of its stroke, you will have no brakes, period! |
