05-17-2019, 04:22 AM | #21 |
Re: Strange Holley 4000
Well, that may be an issue. Looking at this carb it doesn't look like the governor can just be removed and the ports plugged. I'm not entirely invested on using it if it's going to cause me issues. And my rear is 4.11 gears.
05-17-2019, 11:26 AM | #22 |
I guess you could try it since you already have it. You never know, it may fit your needs. If it doesn't work out, then worry about a replacement.
Sal |
05-18-2019, 07:10 AM | #23 |
I want to thank you guys for all the help. You've been great. I was actually apprehensive about asking about this carburater because one of the few things i was able to find on it was the nickname towering inferno and there seems to be many people with strong feelings against it. I'm very grateful to you guys for meeting my question with advice and information rather than ridicule.
05-18-2019, 10:28 AM | #24 |
To me, the towering inferno stories were created by people that don't totally understand carburetors and heard the stories from someone else. Usually people that have never touched one. The teapot is not prone to fires more than any other carburetor model.
Sal |
05-18-2019, 08:36 PM | #25 |
I read, and I believe it was here on ford barn, someone said theyregulated theirs to 5lbs of fuel at idle and they never had an issue and that alot of the issue with this carburator is pumping more fuel to it than either the unit or engine can handle.
05-19-2019, 02:34 PM | #26 |
Sal |
05-19-2019, 05:05 PM | #27 |
05-20-2019, 12:34 AM | #28 |
Kultulz, Thanks for the link. interesting, good info.----Jim
05-20-2019, 05:19 AM | #29 |
Hey Jim, while I have you here and this is off subject ...
You were looking for a dual four setup ACL. Did you see the oddity oldmics came across on another thread? It appears to me to be an open element FORD style? |
05-20-2019, 10:11 AM | #30 |
Kultulz, yes, I did see that A/C thatOldmics found. a while back I was kind of looking for one of the small oval ones. Oldmics, and Ted Eaton think that the carb A/C stud center to center distance is a little off ,if you use an aftermarket intake manifold ( I am using an edelbrock 2x4 intake ). This and the high cost has kind of put me off. If I was going to use it on a T-bird, that would be one thing, but it eventually would be going into the vehicle pictured in my avatar, and not sure I can justify the price for the intended application ( a hot rod ). Thanks for asking. If one could be found at a realistic price ( for me, cause I am cheap. ) I might still try one. --- Jim
05-20-2019, 10:55 AM | #31 |
The only thing wrong with teapot 4000 and 2140 carbs is that they are harder to work on and get right than most carburetors. I think the horror stories (if all true) are from carbs not correctly serviced and possibly caused flooding. Any carb that floods has the chance of a fire after a backfire.
Sal |
05-20-2019, 11:26 AM | #32 |
Heres todays asking price on the Ovals
https://www.ebay.com/itm/1956-1957-F...d=323805396689 And that price is JUST for the air cleaner - NOT the whole pictured setup. Oldmics Last edited by Oldmics; 05-20-2019 at 11:39 AM. |
05-20-2019, 01:01 PM | #33 | |
05-20-2019, 01:09 PM | #34 |
Oldmics, well that is certainly out of my price range for a hot rod. Not saying it is or is not justified given the rarity of them. This one is a reproduction. What would the cost of an original be? Like I said, I am a bit on the stingy side, but if I want something, I usually get it, and if I was restoring a factory 2x4 bird, I guess I would pay the going rate.--- Jim
05-20-2019, 01:36 PM | #35 |
56markII,
It's nice to hear from someone that shares my beliefs about these carburetors. I have also heard that raising the fuel level slightly can cure the hesitation on acceleration, but have never had the opportunity to try it. I also agree that most performance problems are always first blamed on the carburetor before even checking other things like the ignition system for example. Sal |
05-20-2019, 01:41 PM | #36 | |
The price for the air cleaner in that auction is probably about the same amount a new complete T-Bird cost back then. Pretty incredible. Glad I'm not in that league. Sal |
05-20-2019, 07:45 PM | #37 | |
05-20-2019, 07:59 PM | #38 | |
oldmics described it as unique and the photo shows (to me anyways) that the lid skirt does not extend as far down as the 57 ACL. It would allow the element to be exposed to outside air hopefully ingesting air more easily. Maybe I misinterpreted what I saw and he described. What model EDEL do you have? |
05-21-2019, 12:54 AM | #39 |
Kultulz, If I remember correctly, it is a 257, but now that you ask, I need to look at the eng. it is at my brothers shop about 50 miles away, along with my avatar. still have not taken the car out of winter storage. maybe this weekend. will let you know for sure then. --- Jim
05-21-2019, 05:22 AM | #40 |
That's OK Jim. Below is the sizing chart for the ACL fitment on differing systems.
The FM257 is basically the same as both the 56 and 57 FORD intake manifold. Hope it helps. |
