Old 06-10-2012, 08:33 PM   #21
frenchy dehoux
frenchy dehoux's Avatar
Default Re: My new project 1928 Ford!!!!!
And a few more pictures now showing making the rear quarter panels out of the two rear doors and were shortened down to 12 inches in width and the pillar post cut to be use on both sides.
Frenchy
frenchy dehoux is offline   Reply With Quote
Old 06-10-2012, 10:11 PM   #22
Gumpy
Gumpy's Avatar
very nice project was the windshield frame custom made or bought that way? thanks gump
Gumpy is offline   Reply With Quote
Old 06-10-2012, 11:26 PM   #23
frenchy dehoux
I bought this project with this windshield I have always like the look of them.
Frenchy
Old 06-10-2012, 11:35 PM   #24
Bassman/NZ
Bassman/NZ's Avatar
Steve Sellers makes those. Google Sellers Equipped.
Bassman/NZ is offline   Reply With Quote
Old 07-05-2012, 03:32 PM   #25
frenchy dehoux
Here are a few pictures of the progress on my project.
Thanks
Frenchy
Old 07-05-2012, 03:37 PM   #26
frenchy dehoux
Here a few more this is slow process but so far so good. Tomorrow I will post pictures of the inner door frame we are making.
Thanks
Frenchy
Old 07-06-2012, 01:12 PM   #27
frenchy dehoux
A few more pictures of the passenger door. I will have some type of bead roll done.
Frenchy
Old 07-06-2012, 01:49 PM   #28
Ol' Ron
Ol' Ron's Avatar
Two things to add here one: it's quite simple to adapt a Toyota 5 speed to a Ford steel bell housing, I just finished one. Second I just heard of a fellow thats putting two V8 60's to gether to form a V16. nOT SURE WHAT IT'S GOING IN.
Old 07-06-2012, 03:51 PM   #29
frenchy dehoux
Ron thanks for the heads up. Do you know which Toyota model had the 5 speed you mentioned. Do you have pictures of the modification you made you could post.
Thanks
Frenchy
Old 07-06-2012, 06:08 PM   #30
Henry/Kokomo
Henry/Kokomo's Avatar
Frenchy - Your body work skills are pretty impressive! Neat project.
Henry/Kokomo is offline   Reply With Quote
Old 07-06-2012, 07:35 PM   #31
frenchy dehoux
Thanks for the nice compliment I have a long ways to go but I have my son helping me Father and son project which means a lot to me. This is my first project from scratch but there are a lot more nicer project out there on the HAMB. But soon this one will look different. I will try and post more pictures as soon as I have them available.
Frenchy
Old 07-06-2012, 07:52 PM   #32
Ol' Ron
Ol' Ron's Avatar
I think it's a W-55 or W-56, I'm doing the machine work for someone else so I'm not firmiliar with Toyota transmissions. Yes I have some pics of the mods and will post them. Waiting for the bell housing to come back from the sand blasters.
Old 07-06-2012, 09:01 PM   #33
frenchy dehoux
Ron
I appreciate you helping me with this just curious to see how it is set up.
Frenchy
Old 07-06-2012, 09:32 PM   #34
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Originally Posted by frenchy dehoux View Post
Now that I have my 1932 Hot Rod Lincoln done it is time for my next project. Here are a few pictures of this project. I will be installing a 1953 Mercury Flathead a 1953 Mercury transmission 3 speed with 16 inch wire wheels in front with 18 in the rear. Also pictures of the engine.
Frenchy
The engine in the pic has EAB heads witch are 52-53 Ford not Merc. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 07-06-2012, 10:08 PM   #35
Ol' Ron
Ol' Ron's Avatar
This happened to my friend George back a few years ago.
Old 07-07-2012, 03:05 AM   #36
frenchy dehoux
Walt
Thanks I found a pair of Mercury heads and I am having them magnuflux to make sure they are OK to use the ones in the pictures are Ford I am not going to use them unless the other heads have an issue.
Frenchy
Old 07-07-2012, 07:14 AM   #37
Walt Dupont--Me.
Walt
Frenchy
I would use the EAB heads, they are smaller and give more compression. If that is accually a merc engine with the 4in. crank, the EAB heads will bring it right to the front. Walt
Old 07-07-2012, 11:30 AM   #38
frenchy dehoux
Walt
It is a 1953 Mercury motor after I did some research on it.
Thanks
Old 07-07-2012, 06:47 PM   #39
Ol' Ron
Ol' Ron's Avatar
The Merc heads are low compression similar to the 8RT. Not a good choice for a street engine
Old 07-07-2012, 08:42 PM   #40
frenchy dehoux
Ron
How about if I machine the heads to give it the same compression the EAB heads have what do you think.
Thanks
Frenchy
Thread Tools
Display Modes
