Old 11-20-2019, 10:55 PM   #21
Tinker
Tinker's Avatar
Default Re: Spark plug preference...Curious
Use raja ends, so autolite plugs removable ends, works for me 216 or 218 18mm, I can look up the plug to be certain... (in 14mm it's like 486 for autolite). NKG doesn't make them that I know of with screw tops.
Could go with a hotter plug then the champion h10. The new plugs have good reviews. But let us know!!!
Old 11-20-2019, 11:09 PM   #22
AnthonyG
AnthonyG's Avatar
I run a 12V System so not a prob, I know lotís donít but first thing I did was convert to 12V. Bought a blue tooth radio AM/FM & will play music from my iPhone. Havenít installed yet but bought Autolite 3924 resistor type JIC of electronic interference.
Nomad
AnthonyG is offline   Reply With Quote
Old 11-21-2019, 08:25 AM   #23
rockfla
rockfla's Avatar
Originally Posted by Ronnieroadster View Post
The best choice of plug for your Flathead as others have mentioned is the NGK B4L or B6L the NGK plug works perfectly for stock as well as modified applications being 6 or 12 volt neg or positive ground has no effect over the spark plugs performance. The Autolite 216 is a second choice but is in no way as good as the NGK . Champion plugs being made in mexico are prone to failure so what ever you do stay away from that brand. Ask your NAPA salesman for the B6L plug no need to try and figure out the part number.
Ronnieroadster.
Thank you Ronnieroadster, the exact information I was looking for!!!
Old 11-21-2019, 02:17 PM   #24
Ronnieroadster
Ronnieroadster's Avatar
Your welcome
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder and Driver of the First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles burning gasoline.
Old 11-21-2019, 07:55 PM   #25
Bored&Stroked
Bored&Stroked's Avatar
I have a magneto with solid core wires . . . you can probably pick me up on your radio from where you are at now! LOL
Old 11-21-2019, 08:33 PM   #26
oldford2
oldford2's Avatar
Well,I guess rockfla has enough responses to confuse him.
Now let's move on to a new subject:
what oil to use in a flathead?
or, who is more passionate? blonds, brunettes, blackhair or redheads LOL
John
oldford2 is offline   Reply With Quote
Old 11-21-2019, 09:42 PM   #27
cas3
good deals on the ngk's at ebay
