Old 01-08-2019, 10:32 AM   #1
Smitty
Smitty's Avatar
Default B Head Gasket
Does anyone know if a copper B head gasket will work with a stock Model A head? I have motors with high compression heads so I have B head gaskets in stock but current motor has a stock head which is in need of a new gasket.
Thanks, Steve
Smitty is offline   Reply With Quote
Old 01-08-2019, 11:03 AM   #2
Charlie Stephens
Default Re: B Head Gasket
The Model B gasket is shaped for a smaller combustion chamber. Will it work, probably? Would I do it, NO. Lay the Model B gasket on top of the A head and compare. The gasket will overhang the combustion chamber and form a hot spot for detonation.
Charlie Stephens
Old 01-08-2019, 11:55 AM   #3
Jim Brierley
Good advice from Charlie, lay the gasket on the head and see if it fits. The B head has a smaller "waist" area between the valves and cylinder, so may stick out into the combustion chamber, causing a hot-spot.
Jim Brierley is offline   Reply With Quote
Old 01-08-2019, 04:00 PM   #4
Smitty
Smitty's Avatar
Interesting..why then ?
would the Model B gasket be used on the Model A engine with a high compression head?
S
Old 01-08-2019, 04:21 PM   #5
Charlie Stephens
S
Most high compression heads have the same, or similar, combustion chamber footprint as the Model B head. Start laying those gaskets on the head.
Charlie Stephens
Old 01-09-2019, 01:18 PM   #6
Jim Brierley
I beg to differ with Charlie on this. Most older performance aftermarket heads, Winfield, Cyclone, Wieand, etc. used the A gasket. The wider passage between intake valve and cylinder made for better breathing.
Old 01-09-2019, 02:38 PM   #7
Charlie Stephens
Jim,
Correction appreciated.
Charlie Stephens
Thread Tools
Display Modes
