Old 09-20-2016, 09:46 AM   #1
aermotor
Default Stop/tail light
I have a 28 Tudor with the tuna fish can tail light, I also have bumper turning signals. I would like a LED stop/tail light higher up, like in the back window. Any suggestions for a light with out any modifications required? That little old tuna fish can gives me the wilies at night - maybe mount to the spare tire?
John
aermotor is offline   Reply With Quote
Old 09-20-2016, 10:20 AM   #2
29spcoupe
29spcoupe's Avatar
Default Re: Stop/tail light
I fastened my third brake light to the spare tire with leather belts. Just need to tap into the tail and brake light wires. Works fine.
29spcoupe is offline   Reply With Quote
Old 09-20-2016, 12:08 PM   #3
CarlG
CarlG's Avatar
Here's mine: LEDs in the tali lights + LED 3rd light up high.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-20-2016, 02:10 PM   #4
Franchise_24
Franchise_24's Avatar
John
If you are meaning the Drum tail light, just get the LED insert for it. I have a 28 with just 1 tail light, got the LED version and you can see it from a mile away now :-)
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 09-20-2016, 03:43 PM   #5
russcochiolo
russcochiolo's Avatar
This is my solution. All three have 6 volt L.E.D.'s. So far, so good!. Russ
russcochiolo is offline   Reply With Quote
Old 09-20-2016, 04:29 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
My "Third" Brake Light. It has a clear lens but fill with RED LEDs. I believe there was a thread in the past on this, try the search.
I also added a M/C Stop light module. It flashes 5 times before going solid (hopefully to get someone's attention).
Old 09-20-2016, 04:40 PM   #7
Patrick L.
Patrick L.'s Avatar
After being rear-ended I reluctantly installed red lens LEDs along with a third LED brake lite mounted to the spare which contains STOP imprinted in the lens. The hardest part was finding little leather belts to mount it, well, finding the belts was actually easy, finding cheap ones was the problem. [smiley face]
I'm not smart enough to post pictures let alone take them.
Old 09-20-2016, 05:19 PM   #8
29spcoupe
29spcoupe's Avatar
[QUOTE=Patrick L.;1357704] The hardest part was finding little leather belts to mount it, well, finding the belts was actually easy, finding cheap ones was the problem. [smiley face]
Leather dog collars.
Old 09-20-2016, 05:33 PM   #9
Patrick L.
Patrick L.'s Avatar
[QUOTE=29spcoupe;1357731]
Yep, they're hard to find.
Old 09-20-2016, 07:13 PM   #10
updraught
updraught's Avatar
You will probably find that LEDs are quite directional. A bit like a laser beam that has maximum impact if pointed at the head of the following driver, rather than just pointed anywhere.
updraught is offline   Reply With Quote
Old 09-20-2016, 07:40 PM   #11
Y-Blockhead
I use a Velcro strap. Holds good and doesn't look too bad. (Closer picture below.
Updraught, That used to be true but these days you can get LED's that fire at wide angles. The ones I use are 270° Red LED's.
Old 09-20-2016, 08:02 PM   #12
wmws
I mounted my third light LED in the back window. A tudor, and it will just rest on the top of the back seat.
wmws is offline   Reply With Quote
Old 09-20-2016, 08:19 PM   #13
2manycars
2manycars's Avatar
I bought mine from the ad in the model A magazines. It is a thin strip of LEDs in a narrow plastic housing that attaches to the inside of the rear window with sticky buttons. It can be wired as stop only, or as stop and turn signal, or turn signal only. I have it in my coupe and tudor, set up as stop and turn signal.
J & L Enterprises. www.jandlenterprise.com 860-916-3582
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 09-20-2016, 08:45 PM   #14
CT Jack
CT Jack's Avatar
I have a 3rd LED brake light mounted inside the bottom of the rear window on my coupe. This light is 6vdc and also operates as a directional light. It is attached to the glass with 2 small 1/2" squares of heavy duty double faced adhesive backed velcro. This is very visible to the idiots following behind. I replaced the incadescent lamps in my dual rear tail lights with 6vdc yellow and red LED lamps which also operate as brake, directionals, and running lights.
CT Jack is offline   Reply With Quote
Old 09-20-2016, 08:47 PM   #15
Bruce Adams
Bruce Adams's Avatar
I have red LEDs in my tea cups and an all red Third Brakelight on my luggage rack with Velcro so I can rotate it to the rear if the rack is down.
Photo shows left turn signal on.
Bruce Adams is offline   Reply With Quote
Old 09-21-2016, 02:48 AM   #16
updraught
updraught's Avatar
Originally Posted by forever4 View Post
You do realize that most new cars, mid-level trim and above, have LED stop and turn lights, as well as LED headlamps now?
They have nothing in common with lasers for appearance or operation.
Some do. We are not talking new cars here. I'm just saying you may want to check from the position of a following driver what angle works the best. It is a simple test. No animal testing.
Old 09-21-2016, 06:15 AM   #17
brokenspoke
Where did you find a LED for the drum taillight?
brokenspoke is offline   Reply With Quote
Old 09-21-2016, 04:10 PM   #18
Randy(PA)
Brattons - http://https://www.brattons.com/6-vt...ail-light.html
Randy(PA) is offline   Reply With Quote
