02-09-2018, 08:57 AM | #1 |
Manifold heater
Will an Auto-lite model 1110 manifold heater fit a stock manifold or is it for use with a waffle type exhaust manifold? Also would it be comparable with the reproduction firewall doors? Thanks
02-09-2018, 09:11 AM | #2 |
Re: Manifold heater
I don't know the answer to the OP's question but I have a manifold heater like the vendors sell. It says MODEL A on it but it came with the car and no mounting hardware. Does anyone know if I can make what is necessary and where there are plans. Maybe someone has the mounting hardware for sale. Sorry to steal this thread. Jack
02-09-2018, 11:11 AM | #3 |
Re: Manifold heater
IMG_6850.jpghope this helps, I have a stock manifold it has the Auto Lite heater. mine just sites on top no bolts to hold it and it is easy to remove and replace. it looks to have a stock heater door hook up with about 2" of the metal flex pipe between it and the fire wall. not been in the A's long but this is what i can tell you about mine.IMG_6855.jpg
02-09-2018, 02:51 PM | #4 |
Re: Manifold heater
My heater says MODEL A on it and just slips on the top. It has an arrangement for a bolt to go to a head nut, but I just use 10" stainless hose clamps and snug them up after going through and around the manifold and heater.
02-09-2018, 02:52 PM | #5 |
Re: Manifold heater
I believe the AutoLite 111 heater cover goes onto the waffle manifold. It should have to bolt holes on the top.
AL in NY |
02-09-2018, 05:24 PM | #6 |
Re: Manifold heater
The pictures and attachment were right side up on my computer. Last edited by Jwilli; 02-09-2018 at 05:25 PM. Reason: note |
02-09-2018, 06:35 PM | #7 |
Re: Manifold heater
BALING WIRE!
Bill Farmer
02-09-2018, 09:27 PM | #8 |
Re: Manifold heater
02-10-2018, 07:55 AM | #9 |
Re: Manifold heater
02-10-2018, 11:54 AM | #10 |
Re: Manifold heater
I think the pictures that jwilli posted are enough for me to work with. I was concerned about the rattling if I just stuck it on top of the manifold. Jack
02-10-2018, 12:11 PM | #11 | |
Re: Manifold heater
Bill Trivia
02-11-2018, 01:27 AM | #12 |
Re: Manifold heater
I used to have a garage that was stucco. Whenever I need a piece of with I would snip it off the inside of the garage.:-)
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
