10-16-2018, 06:27 PM | #1 |
An oil dipstick dilemma
So, today, I just received my new to me '56 Victoria. All well and good, and pretty much as I expected it would be. However, when I checked the oil, there wasn't any on the dipstick. Now the previous owner told me he just had it changed, and it was full. The dipstick is a very shiny chrome one, one I've never seen before. I looked under the car and didn't see evidence of a leak; however, there is a small amount of oil on the frame cross member. Nothing on the valve covers, oil pan seals, rear of engine where the transmission join together. The bottom of the car looks pretty clean. I added a quart, still didn't show any oil, I added a second quart, still no joy. I then added a THIRD quart, and still no joy. I didn't have any more to add at that point, and that is where I am now. So, the question is, what is going on? Is the oil so new & clean that it doesn't show on this shiny chrome stick?? Have I now over filled the engine by 3 quarts. I'm thinking I'll just take it to a nearby shop, have them drain what amount is in there, and fill w/5 quarts, so I know what I've got. Plus, I can then check that shiny dipstick and know there are 5 quarts.
What does the all wise and knowing Ford Barn have to say?? |
10-16-2018, 06:49 PM | #2 |
Re: An oil dipstick dilemma
I’m assuming it’s still a y block. And I don’t know where the dipstick is on a passenger car motor. In the bird it’s mid block, but isn’t the car up in the timing cover?
To my knowledge no one makes a chrome dipstick or tube for a y block. So it may be you’ve got the wrong one. Clean oil on chrome can be tough to see too. Someone with a car needs to verify the location and then measure the length of both the tube and the stick so you can verify what you’ve got. I suspect it’s wrong. Well, I hope it’s wrong and a fresh oil change isn’t down 3-4 quarts already. |
10-16-2018, 06:57 PM | #3 | |
10-16-2018, 07:00 PM | #4 |
I’d still try to find a longer dipstick, and just put it in and see if you can see oil. Ideally, something long enough to bottom out in the pan. I suspect there are different pan/stick combinations for the 302 also.
10-16-2018, 08:42 PM | #5 |
I'd suggest draining the engine into a clean container that you can measure to see how much oil is in it. You may be surprised to find you have 8 quarts of oil in it.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic |
10-16-2018, 09:19 PM | #6 |
10-17-2018, 05:55 AM | #7 |
10-17-2018, 06:00 AM | #8 |
Yup, I have done the holding it at different angles to see where the oil line is, and still get no joy. I'm still thinking there is enough oil, as the previous owner is adamant that it was full when he shipped it to me. He's been pretty honest about everything else about the car, both the good and the bad, so I tend to believe him. I just can't figure this one out. I'm hoping there is some trick I don't see to ensure the stick is pushed all the way in. I'll let you know, but, I'm concerned that now I've got 3 extra quarts in there. I'll drain the entire system and see how much is there.
10-17-2018, 09:50 AM | #9 |
what does the old owner say.surely he must of had a way of checking it.
10-17-2018, 11:44 AM | #10 |
In 55/56, there were three different engine oil dipsticks among the engine offered. Ford full sized cars, the Y-blocks had the dipstick tube located in the front on the passenger side of the engine. The Thunderbird Y-blocks had the dipstick tube on the side of the engine near the middle of the block. The 223 I-block 6cyl engines had a very short dipstick tube on the driver side of the engine.
Could it be that someone mixed up their dipsticks and accidentally put a 6-cyl dipstick in your Y-block. If so, it will never register any oil on it. Maybe it's a dipstick from a different car altogether. Take photos of the very top and bottom of the dipstick and measure the length of the dipstick. Post that all on here and we can certainly tell you if it is the right dipstick. OOOOPs, never mind. I didn't know someone swapped the engine with a 302. |
10-17-2018, 11:50 AM | #11 | |
10-17-2018, 12:05 PM | #12 |
I strongly suggest not driving it anywhere regardless of whether the crankcase has 3 quarts of oil or way overfilled with 8 quarts.
Just drain the oil pan into a large container, then dump one quart at a time into a 1 qt measuring cup. Count the number of quarts that you have. Don't refill the crankcase with more than 5 quarts initially. Start and run the engine for one minute then shut-off. Add one quart for the oil filter (but you need to check that with the dipstick which is questionable at this time). |
10-17-2018, 12:15 PM | #13 |
Okay, this is kindof MacGyverish, but you could easily make your own dipstick.
Fill the 302 with the proper amount of oil including the filter. Grab a scrap length of 12 gage copper wire. Strip the insulation off of it. Stick the wire all the way down the dipstick tube till it hits the bottom of the oil pan. Cut the wire off about 2 inches above the top of the dipstick tube, slide a small fender washer down into the wire till it rests on top of the dipstick tube. Temporarily tape the washer on the wire with strips of duct tape. Coil the wire around at the top so it is easy to pull the wire out with your finger. Immediately identify the oil level on the wire and mark that spot with a file. The washer can be permanently attached if you wish by brazing it onto the wire or by using spring loaded wire clips above and below it. |
10-17-2018, 02:37 PM | #14 | |
Your suggestion should work, and I might just do it or something like it. |
10-17-2018, 02:45 PM | #15 |
Okay, so here is the status.... I took it to the neighborhood service shop, 10 blocks away, and told them to drain the oil. It sure looked clean, and looked like 8 quarts. Had them fill it back up w/5 quarts. Left the oil filter alone, since it was just changed 20 miles ago. We then tried to look at the dipstick, there was the very slightest sheen on it, nothing that I've ever seen before, and the mechanic couldn't see it either, other than we both know it has 5 quarts. There isn't any evidence of leaking on the bottom of the oil pan, valve gaskets, underside of the car, except for a very small, tiny really, leak by the rear main seal, nothing to worry about at all.
When I got it home, I tried the dipstick again in the garage, again no joy. Took it out side in the bright sunlight, still can't really see any level marker. I asked the Consignment Dealer where I got the car from to ask the previous owner if he replaced the dipstick. I think that is what is going on, and the new one, all chromed up, somehow doesn't quite touch the bottom? Anyway, for now, I'm going to monitor the underside of the car for any new leakage, and keep watching the oil pressure gauge. Thanks for all the suggestions. Keep 'em coming. |
10-17-2018, 02:53 PM | #16 |
Hi '56.........my avatar has a '77 302 in it. My dipstick is 31" long (no laughing guys) and it is 2 and 3/8" from the bottom of the stick to the full mark. The dipstick tube is 19 and 1/2" long as close as I can measure it. I run 6 qts. with filter change to bring it to the full mark. Hope this helps!
10-17-2018, 03:35 PM | #17 |
Are you a club member? Find another similar Ford and compare dipsticks?
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
10-17-2018, 04:22 PM | #18 |
... ... !!! Strut man ... Strut !!!
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
10-17-2018, 04:27 PM | #19 |
If you know what the engine came out of (year - model), you can find the PN in the MPC. Usually the catalog will also give you the engineering part number and that will allow you to walk a yard and possibly find the correct stick and tube.
10-17-2018, 04:36 PM | #20 |
Kul............thanks!! My dipstick has numbers on it which I assume would be the PN. Would that be of help to him?
