10-24-2019, 02:50 PM | #21 |
Re: 40 Ford Replacement Panel
I promised an update and here it is:
The pan from United Pacific is with little doubt the same one supplied (when available) by other vendors. At first glance, it's a beauty. Installation is going slow as many, and I mean MANY measurements are not at all near the authentic pan. Might be okay for a lot of folks but I don't like "good enough"... I like "as authentic". This pan will require cutting, bending, adding material in places, etc. When I'm done, I'll challenge anyone to detect it from Henry steel. Just thought you guys that actually care about doing things correctly would appreciate the update. Yeah, It's better than a bent up and rusted out pan but it's far from a direct replacement.
10-24-2019, 03:26 PM | #22 | |
I located and original 1940 Ford full floor pan with rockers and no rust for my tudor project. My car needs a front floor pan. I'll be installing the Ford floor in my car with the help of an expert metal fabrication man. I will be needing this rear pan that you have reported on. Guess we'll have some fun making it "correct". |
10-24-2019, 05:28 PM | #23 | |
10-24-2019, 05:44 PM | #24 | |
10-24-2019, 07:08 PM | #25 | |
10-25-2019, 10:13 AM | #26 |
10-25-2019, 07:10 PM | #27 | |
10-28-2019, 11:30 AM | #28 |
