01-20-2020, 04:36 PM | #41 | |
Re: Incorrect timing on pulley of 53' Mercury
01-20-2020, 05:25 PM | #42 |
01-20-2020, 08:25 PM | #43 | |
Thank you for your insight. |
01-20-2020, 09:26 PM | #44 |
Don't know whether or not Ford made a 6 cylinder pulley in that configuration ... or if it would fit on a V8 crank.
But, the arithmetic is a tease.
"Remember that when it comes to intelligence, half of all of us are below average." |
01-21-2020, 05:05 AM | #45 |
Merc, just as a sanity check is the discrepancy in the pulley in the right direction to indicate slippage (or some other reason for turning due to load).
Mart. |
01-21-2020, 09:29 AM | #46 |
01-21-2020, 09:43 AM | #47 | |
Since the motor turns clockwise (viewed from the front), and assuming the pulley slipped, this could account for the new location of the TDC location on the pulley. Merc Last edited by Merc Cruzer; 01-21-2020 at 10:41 AM. |
01-21-2020, 10:46 AM | #48 |
Merc, not talking about a Y block ...
Do the ignition math on a Ford 6 cylinder and then V8. Check the initial timing on each. Consider your 28 degree advance (which you just edited out.). Do you see a coincidence? Fun, huh? Probably simply slipped ....
01-21-2020, 11:16 AM | #49 | |
I am thinking that I might be able to pull the bolt and washer from the front of the crank again and blindly feel for both the slot on the pulley and the slot on the crank to see if they are lined up or not. Only way to do it is with a mirror. I do have a cable that attaches to my cell phone that is a camera with a light on the end . Might give that a try. Slippage, still seams to be the most logical explanation. |
01-21-2020, 12:36 PM | #50 |
When I blow up the picture in post # 36 I think I see the woodruff key in the slot that is broken out of the pulley. If so, it is not slipped.
01-21-2020, 03:06 PM | #51 | |
But from what I could see, I believe the 6 cyl. pulley is 2 grooved for the power steering application. (not positive)
01-21-2020, 04:38 PM | #52 |
The OHV 6 cyl have a bit different style of pulley.
With some mass closest to timing cover. |
01-21-2020, 05:23 PM | #53 | |||
The mystery remains. Last edited by Merc Cruzer; 01-21-2020 at 05:28 PM. |
01-21-2020, 05:44 PM | #54 |
How long has this engine been together and running? Is there a chance the timing gears are not lined up correctly, but the timing has been moved enough to compensate to make it run?
3blap. |
01-21-2020, 06:38 PM | #55 | |
For discussion sake, how would a engine run that had the "timing moved enough to compensate to make it run"? I would be interesting in knowing, to see if my engine is exhibiting any of those symptoms. I have posted this previously, but for those of you wanting to know it sounds, come take a ride with me: https://www.youtube.com/watch?v=W8ekRfWS_eE For those who say, any car runs well when it is warm, or too much music, I can't hear the engine, come take another ride with me, but you will have to put on a coat for this one. By the way I keep the choke turned off and it was 38 degrees that day: https://www.youtube.com/watch?v=V5biC4qjjTE&t=85s Last edited by Merc Cruzer; 01-22-2020 at 12:31 PM. |
01-22-2020, 11:29 AM | #56 |
Timing marks look good. Crank pulley looks good.
Yeah, I don't know about the timing being off and running still. I think I managed to do that as a kid (on a OHV engine) but it ran like poop. No way you'd put over 8K miles on it like that. You know, I've heard (but have zero experience) that those original style cam gears will slip on itself, hence the solid aftermarket aluminum parts. If that did slip, I think it would still run with a twist of the distributor to compensate. I'll have to go back and look to see if the timing mark is way after TDC to run correctly/be in time... is that what's the problem? I'll have to go back and read the original post. |
01-22-2020, 12:27 PM | #57 | |
Really, I have no problem or issues with the running/performance of the engine, I was just wondering why when I use a timing light (rather than tuning it with a vacuum gauge, the way I was taught) it reads way off. (an 1 1/2" before the timing button on the pulley) I thought maybe someone had run into this previously and could provide insight. Maybe I should have just left the timing light in the drawer where it has been for many, many years, and will remain. Thank you all for your reply's and suggestions, it is always a pleasure to learn from you. |
01-22-2020, 01:19 PM | #58 |
Merc, using whatever reference point for a start ... like the slot ... measure and see if the "timing button" is in the same place on both the installed pulley and your old pulley.
01-22-2020, 03:25 PM | #59 |
From what I can tell, by putting the old pulley over the front of the new one, (shaft towards the engine) they appear to be the same.
02-03-2020, 02:17 PM | #60 |
First, just a thank you all for your assistance.
I did get a chance to do a test run on Sunday. The car starts allot easier and quicker (one revolution). The engine seems noticeably quieter. Not sure if there is more power, if so it is not noticeable, but it does seem smother. Overall, I like that fact that I can now use the original timing mark in conjunction with my timing light, the original goal for this post. Thanks again, End post. |
