Old 09-23-2019, 01:43 PM   #1
Heard
Heard's Avatar
Default Wiring pic needed
Can someone please post a pic or two of how the wiring harness routes from the bottom of the steering column toward the front cross member?
I'm specifically trying to see how the headlight wiring gets there.
This is for my '35 pickup that I'm wiring similar to a '39. The original wiring was pretty much non-existent.
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 09-23-2019, 02:45 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Wiring pic needed
I think that 1935 - 1936 Ford pickup and car headlight wiring is the same. If that is the case, the following routing diagram showing the actual path of wiring may be of help to you.
Old 09-23-2019, 03:52 PM   #3
Heard
Heard's Avatar
Well, I need a picture. I want to know how it is routed over/under/around the front cross member and into the fender wells.
Old 09-23-2019, 04:05 PM   #4
petehoovie
petehoovie's Avatar
You need more than one picture....
Old 09-23-2019, 06:47 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Petehoovie says: "[QUOTE] I think that 1935 - 1936 Ford pickup and car headlight wiring is the same."
Hmmm Heard, now if you only knew someone with a '36 car...…! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-24-2019, 06:29 AM   #6
Heard
Heard's Avatar
DD, that '36 car ain't got a lick of original wiring anywhere. Not that I'm going for originality, but....
Old 09-24-2019, 07:06 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Heard, drive on up here to Rising Sun, Maryland in that cool looking 36 3w, that I never got to see at any of Vic's gatherings , and you can check out the wiring on my mostly all original '35 fordor sedan
PS, I may already have some pics of the wiring in the area you need. All I need to do is find them
John
Old 09-24-2019, 11:42 AM   #8
Heard
Heard's Avatar
Hey John! That would be quite an adventure for sure as I'm not sure the coupe is up for it.
Old 09-24-2019, 10:34 PM   #9
Tinker
Tinker's Avatar
38 trucks had about the same as your asking for a 35. Couple clips. but Vanpelts diagram covers it. Not sure if I'd worry about where it goes if you are changing things up anyway. My 36 coupe has stock electrical routing if you like, let me know.
Old 09-25-2019, 09:55 AM   #10
JM 35 Sedan
Heard, didn't you put a T5 5speed overdrive, and retain the closed torque tube banjo rear in your coupe? If so that baby should motor on down (or up ) the road with no sweat, assuming the engine is strong/capable
I'm looking for those pictures now, if I can't find them, I can take more. PU should be same as passenger car. Also, there could be some info with pics in the V-8 Clubs 1935-36 Book.
Van Pelts website is probably mostly schematic type illustrations. You need actual photos IMO.
John
Old 09-25-2019, 12:03 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Hey John....That T5 W/TORQUE TUBE went into the '35 pick-up that Heard is trying to finish-up. I'm sure the 3-window will end-up with a T5 once this truck gets done. Early pics from the T5 install below! DD
T5 W/TORQUE TUBE
Old 09-25-2019, 03:15 PM   #12
Heard
Heard's Avatar
Yes John. Pics is what I need.
And Dick is correct. T5 is going in the truck. The coupe has gone from bad shifting to worse so it'll get a makeover if I live long enough to get it done. I already have the Jeep tranny and the correct Chevy tranny.
Old 09-25-2019, 10:26 PM   #13
Don Rogers
Don Rogers's Avatar
Heard, Here are 3 photos showing the wire routing from the bottom of the steering column to the driver's side head light harness, across the radiator to the passenger side harness.
Hope it helps.
Don Rogers is offline   Reply With Quote
Old 09-27-2019, 06:53 AM   #14
Heard
Heard's Avatar
Thanks Don. Just what I was looking for!
Old 09-27-2019, 12:13 PM   #15
JM 35 Sedan
Heard, I looked, but couldn't find my pictures. I can retake some shots for you if you want to see more after checking out the pictures Don sent. Just let me know with an email or PM.
John
