02-07-2015, 09:30 AM | #1 |
30 vs 31 front fenders
Is it possible to remove the apron extension on a 30 fender and use it on a 31?
02-07-2015, 09:45 AM | #2 |
Re: 30 vs 31 front fenders
The flange may need to be extended to have enough room to make room for the bolt holes. The flange on some of the 30 fenders I have seen were not long enough to allow for the elongated bolt holes used on the 31. Yes, Ford had oval holes to allow for room with fitting.
02-07-2015, 09:46 AM | #3 |
Yes but you will need to extend that flange by about .250-.350 where you can drill the holes to bolt the one-piece aprons to.
02-07-2015, 09:47 AM | #4 |
