Old 01-09-2020, 02:00 PM   #1
doug.nichols
doug.nichols's Avatar
Smile Locked Rear Wheel
I just finished installing a Mitchel OD and transmission. The car is still up on jack stands. When I put both the tranny and OD in neutral, the left rear wheel turns freely by hand. The right rear wheel, however, will not turn. Before I attempt to drive, do I have a problem or is this just the rear end behaving normally?
doug.nichols is offline   Reply With Quote
Old 01-09-2020, 03:23 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Locked Rear Wheel
Taking a stab in he dark here but perhaps during removal or replacement of the rear end, the hand brake became locked on. The activating mechanism may have gone "over center" and is locked on. This wouldn't normally happen - a series of worn components and linkages may make it possible. Try the levers behind the backing plate for movement. If one is tight (most likely the hand brake one), I think you have isolated the problem. If you find a tight one, try pulling it back (that won't help if the foot brake is the culprit). You might get lucky but don't just think all is now well, FIX IT properly before you drive again for safety reasons.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-09-2020, 04:55 PM   #3
Patrick L.
Patrick L.'s Avatar
Parking brake is my thought also.
Old 01-09-2020, 06:32 PM   #4
doug.nichols
I will pursue the parking brake route and let you know. Thanks.
Old 01-09-2020, 07:21 PM   #5
doug.nichols
Thank you Synchro99 and PatrickL. It was the e-brake indeed. It had not fully retracted. Seems that return spring(?) isn't pulling it fully back.
Old 01-11-2020, 08:02 AM   #6
Patrick L.
Patrick L.'s Avatar
Thats good to hear.
Old 01-11-2020, 08:22 AM   #7
chap52
chap52's Avatar
Good catch. Glad it was an easy fix... Chap
chap52 is offline   Reply With Quote
