02-26-2015, 02:05 PM | #1 |
duals/neutral saf switch
Putting dual exhausts on 54 merc and need to move the neutral safety switch up to clear the stock dual exhaust manifold. Must have been a stock bracket for it but can't find one.
Any ideas |
02-26-2015, 05:23 PM | #2 |
Re: duals/neutral saf switch
My '55 Ford has factory dual exhaust, Ford-o-matic with the starter neutral switch, all factory. You shouldn't need to move anything. The neutral switch hangs off a bracket mounted at the base of the steering column on the opposite side of where the exhaust passes thru.
02-27-2015, 02:09 PM | #3 |
Thks for the comeback. My NS switch sits between the column and exhaust manifold so is a problem. Maybe Merc and Ford are diff. Looks like a complicated fabrication job
coming up. |
02-27-2015, 03:43 PM | #4 |
Evidently dual exhaust weren't a factory option on '54 Mercury's, or the safety switch wouldn't be in the way. I thought duals were optional, but never verified it.
Sal |
02-27-2015, 05:18 PM | #5 |
In 1954 only the Ford 256 Police Interceptor which used a Mercury Y-block had dual exhaust.There is a picture of it in this: http://www.ebay.com/itm/Original-195...ea4363&vxp=mtr I have had guys in my 1952-59 Ford Group deal with the same issue you have because you probably have 1955-57 manifolds so you need a 55-56 bracket and switch.Best bet is here: www.owenssalvage.com
02-27-2015, 09:54 PM | #6 |
Sal |
02-27-2015, 10:13 PM | #7 |
Boy!!!!!!!!!!!!
Thks for all the prompt feedbacks. Jeff, thks for the links, I'll check them out asap. Don't need this until I get it out of the body shop after a sideswipe deal. Glad the other guy paid his insurance. |
