Old 05-23-2018, 12:05 PM   #1
Newc
Newc's Avatar
Default Reverse Axle key photos
Here are the photos hopefully
Old 05-23-2018, 12:08 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Reverse Axle key photos
I missed something. What the hell happened there!?
Seth Swoboda is offline   Reply With Quote
Old 05-23-2018, 12:09 PM   #3
RalphM
RalphM's Avatar
Wow, what a mess!
That’s an expensive mistake.
RalphM is offline   Reply With Quote
Old 05-23-2018, 12:15 PM   #4
petehoovie
petehoovie's Avatar
I don't get it.....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 05-23-2018, 12:21 PM   #5
Automotive Stud
Automotive Stud's Avatar
From his post history
https://www.fordbarn.com/forum/showt...04#post1632204
I'm still not convinced, I think the correct puller could have removed it.
Automotive Stud is offline   Reply With Quote
Old 05-23-2018, 12:21 PM   #6
cmbrucew
cmbrucew's Avatar
That looks like a two six pack job to me.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 05-23-2018, 12:48 PM   #7
AlexLohmann1
AlexLohmann1's Avatar
Wow! Not sure that was the way to remove it [emoji23]
Sent from my SM-G955U using Tapatalk
AlexLohmann1 is offline   Reply With Quote
Old 05-23-2018, 01:14 PM   #8
ford38v8
ford38v8's Avatar
On the positive side, something good can come of this:
That axle can be made into a Hard Luck Award Trophy.
Alan
Old 05-23-2018, 01:39 PM   #9
J Franklin
J Franklin's Avatar
Did somebody super glue that hub/axle?!
Old 05-23-2018, 02:57 PM   #10
Mart
Mart's Avatar
For the life of me I cannot believe that was a result of an incorrectly fitted key. The key fitment can't be THAT critical, surely.
I'm just glad that I have invested in what I believe is a decent puller and have never had to resort to such butchery. I have the VP puller.
Mart.
Old 05-23-2018, 03:03 PM   #11
Russ/40
Russ/40's Avatar
You must feel much better now.
Russ/40 is offline   Reply With Quote
Old 05-23-2018, 03:35 PM   #12
ford38v8
ford38v8's Avatar
Mart.
Speculation here:
It looks like the key was run up the ramp too high (perhaps an extra long key?), jamming against the hub and preventing the taper from seating. With the axle-nut then torqued down against the offset hub, the key/hub taking all the force, the key then rolled over within the hub. The pics show the use of a cutoff blade everywhere on the drum and axle itself, with some bluing at a few hotspots.
I know, takes all the fun out of it, huh?
Alan
Old 05-23-2018, 03:47 PM   #13
jimTN
I do not believe the nut had full torque. Look at the first picture and it looks like part of the threads are worn off to less than the diameter out at the end of the axle.
jimTN is online now   Reply With Quote
Old 05-23-2018, 04:09 PM   #14
34fordy
34fordy's Avatar
I believe it is easy for any of us to feel we could have removed the drum/hub without damaging the axle--However, it seems this fellow tried quite a few methods unsuccessfully with a lot of anguish along the way--When you have had such good luck with a Wilson or VP puller it is hard to imagine a hub that you could not remove--I think I would have used a cut off wheel down the length of the key way to keep from harming the axle, releasing the grip of the taper. I would wager there are quite a few Barners that would have liked to have had a crack at this job!!!
34fordy is offline   Reply With Quote
Old 05-23-2018, 04:21 PM   #15
tubman
tubman's Avatar
This is one of the reasons I'm a "shoebox guy".
tubman is online now   Reply With Quote
Old 05-23-2018, 04:36 PM   #16
Mart
Mart's Avatar
^^ Don't blame you, Tubs.
Old 05-23-2018, 06:48 PM   #17
Newc
Newc's Avatar
Hi again all; I was told that the key was installed with a sharp [square] edge to the inside, and that sharp edge dug into the hub taper keyway and "locked" the hub on the axle. All those keys have one rounded end that is supposed to go inward and facing upward to prevent a 'dig in'. That is my take. The parts were at our RG#85 meeting and left on my scrap pile. That's all I know Newc
Old 05-24-2018, 11:46 AM   #18
5lugnuts
I feel sorry for the poor guy who only wanted to check his brakes. My heart goes out to him.
Now, if I find myself in the same initial situation (darn thing won't come off), what should I do so as to not ruin the axle, hub and drum?
Would this be a possible course of action? Drill a hole into the key parallel with the axle, then tap the hole and thread a small bolt into the threaded hole and somehow use one of those bearing pullers or slide hammers they use to pull out dents in sheet metal to yank the key out? would that be possible? How about drilling above the key into the hub to try and free up the jam between the key and the hub?
This must be a somewhat common happening and I'm curious what you guys have done to get the hub off without ruining expensive parts?
5lugnuts is offline   Reply With Quote
Old 05-24-2018, 12:21 PM   #19
J Franklin
J Franklin's Avatar
I wonder if the brakes were ok after all this mess?
Old 05-24-2018, 02:33 PM   #20
Automotive Stud
Use the correct hub puller, K.R. Wilson ABV-156.
Thread Tools
Display Modes
