Old 11-26-2016, 01:19 PM   #1
37fatfender
37fatfender's Avatar
Default brake lines ?
I am replacing brake lines on my chassis and I need to connect two length of 3/16 line. Can I use a compression o ring fitting or must I double flare both ends? I think I heard compression rings are a no no? But its been a long time since I have done this kind of thing.
37fatfender is offline   Reply With Quote
Old 11-26-2016, 01:31 PM   #2
rich b
rich b's Avatar
Default Re: brake lines ?
Double flare.
rich b is offline   Reply With Quote
Old 11-26-2016, 01:41 PM   #3
Marvin/TN
Send a message via AIM to Marvin/TN
There is a fitting that accepts flare lines that you can connect the two lines.
Marvin/TN is offline   Reply With Quote
Old 11-26-2016, 01:51 PM   #4
JSeery
JSeery's Avatar
Needs to be double flare. A compression fitting is not designed for that much pressure.
Old 11-26-2016, 04:37 PM   #5
Barry-ct
Barry-ct's Avatar
Absolutely do not use a compression fitting. Suicide waiting to happen. Use a union fitting that will accept the flared fittings.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 11-26-2016, 06:03 PM   #6
fordv8j
fordv8j's Avatar
I got my brake lines at NAPA,they had a fitting for that purpose,worked on both our 38s for years, its just a coupling that the fittings screws into, the lines had the fittings on them
fordv8j is offline   Reply With Quote
