Old 10-14-2019, 10:23 PM   #1
mrtexas
mrtexas's Avatar
Default Wood varnish color match on 49 woodie
I'm very pleased with the varnish color match on the leading edge of my doors. Leading edge was rubbing against the fender so had to grind down the edge a bit to make it fit. Can see in picture but harder to see when installed on the door. Used 3 coats of Epiphanes varnish. Wood is approximately 15 years old. Getting ready to sell the old girl as 4 antique cars is too many to keep going. I let this one sit for 3 years and an having to fix quite a few things to get it going again like wood varnishing on front doors and a few other spots, electric fuel pump and gas sender replacement due to ethanol gas, fix overheating, transmission work, install inside handles correctly, etc.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
