09-23-2019, 07:07 PM | #1 |
Install Optima Battery in Ford case
Who installs Optima batteries in Ford script reproduction cases? I have read a lot about this on Fordbarn and its time I give this a try. All help appreciated.
09-23-2019, 08:01 PM | #2 |
Re: Install Optima Battery in Ford case
you can install a 6V Optima in a Ford V8 case. they are 1" longer than a Model A case.
I did try to figure out a way of doing just that. but failed. it would pretty neat if someone comes up with a way. |
09-23-2019, 09:24 PM | #3 |
I made my own battery tie down out of aluminum stock . I put the battery on an angle connected it to the hold down screws also used the model a square hold down . Works great.
09-24-2019, 05:58 AM | #4 |
Why spend that much for just a battery. Optima sure has good marketing.
09-24-2019, 06:45 AM | #5 |
09-24-2019, 08:55 AM | #6 |
09-24-2019, 09:38 AM | #7 |
09-24-2019, 10:03 AM | #8 | |
I have a gutted script case, the fit would be very tight, have to take a lot of structure out |
09-24-2019, 11:41 AM | #9 |
When I threw in my two cents I should have said . . "If we are refering to the optima three cell 6 volt battery . . ."
https://www.amazon.com/Optima-Batter...30807079&psc=1 |
