08-15-2015, 11:22 AM | #21 |
Re: Sudden starter failure
also make sure your starter armature is not bent
08-15-2015, 05:02 PM | #22 |
A LOOOONG crank with the key "off", should tell you if the starter is making it's PROPER, NICE SOUND. That PAYS .1 flat rate
SA Dad
08-15-2015, 05:04 PM | #23 |
Aahh ok. Not many things pay .1 nowadays .
08-15-2015, 06:18 PM | #24 |
I had simular issues... cleaning the ground at the frame and connections at battery helped.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
08-15-2015, 09:38 PM | #25 | |
The battery was just low 'cuz I've been driving it a half mile a day around the corner to work, mostly. It's all charged up now. Chuck
... prosperity is not the product of charity but of industry - HENRY FORD |
08-15-2015, 11:57 PM | #26 |
However, short drives like you mentioned, are also detrimental to the engine, as condensate doesn't get burned off and nasties the oil, ect. |
08-16-2015, 12:38 AM | #27 |
Thanx Chuck, I do have a 6v trickle charger (often just too lazy to pull back the carpet and use it). I've had the car a year and have NO IDEA how old the battery is. My ammeter shows a charge of 10A, and I think I should adjust the generator a bit lower, and combine that with the trickle charger. Chuck
08-16-2015, 09:39 AM | #28 | |
08-16-2015, 10:51 AM | #29 | |
08-16-2015, 10:54 AM | #30 |
A head nut works good when connecting the charger to a ground
08-16-2015, 10:57 AM | #31 |
So it doesn't hurt 'anything' to connect the trickle charger right to the car without isolating it to the battery only?
Glenn (newbie) |
08-16-2015, 11:33 AM | #32 | |
By the way, 2 Amps for too long a time, WILL cook a battery!!! Tom W. uses a 24 hour timer, just to give it a SHOT, now & then. I screwed a plug in adapter in my ceiling light & plug the charger into it, then the charger ONLY runs when the light is on! The Dog calls it, "OL' BILLS' CHEEP OAKIE INTERMITTENT BATTERY CHARGER-UPPER" If you can find a 6 Volt "float" charger, you can leave them on indefinitely, as they only put out about 400 MILLIAMPS, (less than 1/2 Amp) TOM W, what is a trick way we can use a Harbor Freight 12 VOLT float charger, on a 6 VOLT SYSTEM? Cars that are driven regularly, RARELY need the battery charged! Fortunately, here, we can drive ours pretty much YEAR ROUND. Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 08-16-2015 at 02:50 PM. |
08-16-2015, 08:10 PM | #33 | |
On another occasion I had a 3 amp charger catch on fire overnight. Luckily the charger was setting on the top tank of the radiator so the fire never spread past the charger. Now I leave the batteries alone unless they sat for a couple months and I happen to be in the garage for 15 minutes or so, then I'll connect my 6 amp charger for the time I'm in the garage. |
08-16-2015, 10:59 PM | #34 | |
http://www.amazon.com/Battery-Tender.../dp/B000CIPHT4
08-17-2015, 11:53 PM | #35 |
It could be done, Katy. The hot desert Dog Days of Summer are almost over.
08-17-2015, 11:54 PM | #36 | |
08-19-2015, 01:01 AM | #37 | |
That will make the difference with ME (lazy arse) charging with my Battery Butler or not. Raising the hood and doing it crosses my "lazy barrier" from going in and undoing the carpeting etc. You may have extended my life with "Bonnie". BTW, the "Battery Butler" (trickle charger) DOES shut off when battery if full, and comes back on as needed. Mine is 6v, but it is sold in 12v also. Chuck
