Old 12-08-2018, 06:33 PM   #1
fordlovr
fordlovr's Avatar
Default Oil Leak
what do the team think the problem is here? It looks like a shadow on the backing plate but is a thin film of oil. you can see the drip at the bottom.. OOPS. LOOKS LIKE I LOST THE PICS!!!
fordlovr is offline   Reply With Quote
Old 12-08-2018, 07:27 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Oil Leak
Pictures probably aren't needed. A thin film of oil on a backing plate with a drip at the bottom seems normal and not a problem. 8^) Jack E/NJ
Old 12-09-2018, 09:36 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
If you're talking about a brake backing plate - with a drip at the bottom, to me that means a leaking wheel cylinder . . . which is a problem that needs to be fixed.
Old 12-09-2018, 05:32 PM   #4
V12Bill
V12Bill's Avatar
In what world is a leak on the backing plate acceptable???
V12Bill is offline   Reply With Quote
Old 12-09-2018, 05:44 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
Agreed. Brake fluid wouldn't be acceptable if that's what the oil is. Jack E/NJ
Old 12-09-2018, 08:42 PM   #6
V12Bill
V12Bill's Avatar
Any oil is not acceptable. It could be differential oil soaking the shoes.
Old 12-11-2018, 02:45 AM   #7
fordlovr
fordlovr's Avatar
This is what I was thinking. So.... would/could it be a seal leaking?
Old 12-11-2018, 06:47 AM   #8
adileo
adileo's Avatar
I had this on my F1. It was a blown shock.
I did, as I suggest you do, double check for leaking wheel cylinder.
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
