04-30-2019, 09:22 AM | #1 |
Rear suspension
I recently purchased a 31 A coupe, that has many modifications. My question is the rear suspension. Whenever i hit uneven surfaces the rear suspension tends to make quite a bit of noise. I went underneath and it looks like the top of spring hits the top of the vehicle. How can i go about this? Thanks
04-30-2019, 09:25 AM | #2 |
Re: Rear suspension
Originally there was a piece of frame webbing riveted to the body to stop metal to metal contact
04-30-2019, 09:37 AM | #3 |
Re: Rear suspension
It may well be "spring shackle connection" wear. The spring perch which is part of the rear trumpet housings is prone to wear because of the constant loading of the car. I have seen these shackle connection points worn practically through to dropping the shackle.
A lot of wear and lack of grease may be what you're hearing? Joe K
Shudda kept the horse. |
04-30-2019, 10:09 AM | #4 | |
Re: Rear suspension
04-30-2019, 11:27 AM | #5 |
Re: Rear suspension
If you take the spring out, check to see that the top leaf is rounded to fit into the crossmember.
04-30-2019, 12:00 PM | #6 |
Re: Rear suspension
Pictures https://photos.app.goo.gl/QHYkyHa9j6prq6As9 |
04-30-2019, 12:07 PM | #7 |
Re: Rear suspension
All bets are off. Can't really help you with that setup but something must be loose up there.
04-30-2019, 02:14 PM | #8 |
Re: Rear suspension
referring to the "modifications", a picture would help.
Paul in CT |
04-30-2019, 02:26 PM | #9 | |
Re: Rear suspension
which is in the 3rd. photo. Get under the car and spend some time looking.. |
04-30-2019, 03:26 PM | #10 |
Re: Rear suspension
Someone at HAMB probably has had similar issues.
Joe K
