Old 10-27-2017, 01:55 PM   #1
NSDWS
NSDWS's Avatar
Default Dustless Blasting
Anyone here ever use a dustless blasting vendor or just the process? My 39 is looking bad along the drip rails and since this process is less harmful to the sheetmetal (so they say) I would like to get the area cleaned down to bare to see what I am dealing with. How does this compare to sandblasting in cost? I don't want to just wire brush and sand it.
Doug
Doug
NSDWS is offline   Reply With Quote
Old 10-27-2017, 04:06 PM   #2
rich b
rich b's Avatar
Default Re: Dustless Blasting
Personally; I think you would have a lot more control over the process; by masking it tight with several layers of duct tape and blasting it with a small hand blasting gun or bucket blaster. Of course, you need to cover the rest of car. Done lots of small stuff like that over the years, with good results.
Can't imagine what the wet blaster guy would charge you to show up and set up a small job, like that.
rich b is offline   Reply With Quote
Old 10-27-2017, 09:45 PM   #3
d.conrad
d.conrad's Avatar
I had my 51 Chevy dustless blasted and no warping. Did a great job.
d.conrad is offline   Reply With Quote
Old 10-28-2017, 01:04 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Those holes for mounting stainless trim on the rear fender make the car in your picture a 1952 Chevy. '51s did not have this trim piece. 1952 pictured below! DD
T5 W/TORQUE TUBE
I may not be the BEST, but I'll do 'til he gets here!
Old 10-28-2017, 03:00 PM   #5
TagMan
A friend of mine had the roof, doors and hood on his '58 pickup truck wet blasted and the guy that did the blasting had no idea what he was doing. All four items got warped and my friend had a hell of a time fixing the doors & roof and had to get a new hood. The blaster must have had the pressure turned up to max pressure. Make sure the guy you use has blasted sheet metal before and knows what he's doing.
TagMan is offline   Reply With Quote
Old 10-28-2017, 03:18 PM   #6
jim1932
jim1932's Avatar
depends on who does it. I know a guy who blasts and sells blasting equipment who says it is the wrong process for a car. Have you thought of powder blasting?
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 10-28-2017, 04:18 PM   #7
rich b
rich b's Avatar
It seems to me that the dustless blasting system is promoted as a business venture that requires only a minimum of training to go out and make the "big bucks"; as such you may have a good experience such as d. conrad reported or a terrible experience as related by TagMan. Probably a good idea to do a little more research on the actual operator; more so than the process. Just say'n.
Old 10-28-2017, 04:27 PM   #8
v8nut
v8nut's Avatar
I had the bare chassis of my '35 phaeton dustless blasted and I was very satisfied with the work and the result. Jim in San Jose.
v8nut is offline   Reply With Quote
Old 10-28-2017, 07:58 PM   #9
pooch
pooch's Avatar
If you do not know the guy or his reputaion , have him do a scrap panel first.
pooch is offline   Reply With Quote
Old 10-29-2017, 10:26 AM   #10
rod father 1944
rod father 1944's Avatar
I had a friend have his 41 chevy truck dustless blasted and it warped the doors and cab. I think he used too much pressure. I had a lot of work straighting it out, Never blast sheet metal unless you use low pressure,about 30 lbs and nozzle at 45 degree angle.
rod father 1944 is offline   Reply With Quote
Old 10-29-2017, 10:37 AM   #11
flatheadmurre
flatheadmurre's Avatar
Dustless blasting can be a lot of things...the constructions version seems to use pretty coarse sand while the more refined types uses crushed glass.
So different media and pressure makes it go from mild to wild still calling it dustless blasting....
Thread Tools
Display Modes
