01-03-2017, 09:18 PM | #1 |
Removing spot welds
Wow rust 911 sure worked good on this piece!
I need to remove this hinge on the gas door to straighten it out. What is the best way to remove the 10 small spot welds? Want to minimize damage this hard to find 41-48 woodie gas door.
41 woodie https://41fordwoodie.weebly.com/ Last edited by mrtexas; 01-03-2017 at 09:32 PM. |
01-03-2017, 09:45 PM | #2 |
Re: Removing spot welds
Goggle "spot weld cutters".
01-03-2017, 09:45 PM | #3 |
01-03-2017, 10:15 PM | #4 |
I found that a small hand held "Dremel high speed tool with a small thin 3/4 inch dia. Diamond wheel worked well, also used this tool to take off the original spot welds that are very sharp around the Firewall
01-03-2017, 10:59 PM | #5 | |
01-03-2017, 11:06 PM | #6 |
41 woodie https://41fordwoodie.weebly.com/ |
01-04-2017, 08:48 AM | #7 |
Replacing the old door to the hinge lets you use the spot welds as a reference point. They may not be exactly the same on the other door so you need to be careful you get the alignment right. You may already know this but...
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
01-04-2017, 10:19 AM | #8 |
01-04-2017, 10:25 AM | #9 |
I always thought the woody gas door has a slightly different curvature then the regular passenger car gas door.
01-04-2017, 10:33 AM | #10 |
Blair tools makes hole cutters in different sizes that work great on spot welds. I got mine through Amazon.
01-04-2017, 10:37 AM | #11 | |
Needs some work?
41 woodie https://41fordwoodie.weebly.com/ Last edited by mrtexas; 01-04-2017 at 10:45 AM. |
01-04-2017, 10:47 AM | #12 | |
01-04-2017, 11:48 AM | #13 |
The gas door fits the cavity on the fender the same way a glove box door aligns with the dash. I'm thinking the gas door is specific to woodie only fender applications..Bill
01-04-2017, 11:57 AM | #14 |
I have never used the ones from Harbor Freight but have used those made by Blair.They work very well but it is best to drill a small starting point just be careful and not go all the way through both (or more) layers. The cutters are fragile and can break if you let them skip out of the intended weld spot. I have been using this type of cutter for 40 plus years.
01-04-2017, 01:24 PM | #15 |
Yes, 41 woodie came with a sedan gas door that didn't fit. Hinge and door are different.
01-04-2017, 01:26 PM | #16 |
Hard to tell by the pictures, but do you think a little bending over a large diameter pipe will get it to sit right or is it a little too short?
01-04-2017, 05:30 PM | #17 |
I'd make a template out of thin sheet metal or poster paper and compare it to the door you have or use to reshape it...... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
