06-04-2013, 05:06 AM | #1 |
Good seal with Thermo quail?
I have an older Thermo Quail and it does not seal well. The hinge seems to have loosened up and even with a new red top gasket it does not create a tight seal.
I have a Boyce Motometer on another car that fits with precision nice and tight Is mine just worn out or is this just the way the design is on these quails?? Is this a typical failure point?
31 Deluxe Roadster Last edited by bluesman31; 06-04-2013 at 06:26 AM. |
06-04-2013, 09:55 AM | #2 |
Re: Good seal with Thermo quail?
What's leaking?? There is another gasket UNDER what the quail attaches to. You could also try double gasketing under the quail cap.
Paul in CT |
06-04-2013, 10:45 AM | #3 |
I have used gas gauge shim washers under the gasket along with some silicone sealant to hold everything in place. Seemed to work OK, ie: no leaks.
06-04-2013, 11:04 AM | #4 |
My quail cap was leaking too, so I used a 2nd gasket and (knock on wood) no leaks so far
1929 Model A Ford Coupe |
06-04-2013, 01:58 PM | #5 |
I use a big O-ring.
06-04-2013, 05:01 PM | #6 |
Hugh |
06-04-2013, 06:25 PM | #7 |
I think so my motometer started to leak last time out i checked and found the same loose top i will try fresh gaskets first than move up to a big fat O ring
06-04-2013, 07:13 PM | #8 |
O ring from harbour freight fixed mine.
06-04-2013, 08:44 PM | #9 |
The big suppliers sell a very thick o-ring to go under the top half for worn out hinge situations.
