10-23-2018, 05:57 PM | #1 |
Halibrand 201
Hey fellas , can anyone recommend someone who sells rebuild kits ie bearings gaskets ect for halibrand 201 rearend ? Seen speedway sells everything separately but not sure if it’s off shore bearings and the last thing I want is bearing failure. Any recommendations would be appreciated. Thanks
10-23-2018, 06:09 PM | #2 |
Re: Halibrand 201
Check with Gearhead QCE over on the HAMB. He's the resident guy for QC repairs.
10-23-2018, 06:14 PM | #3 |
Re: Halibrand 201
Check with Kenny @ Speedway Engineering in LA
10-23-2018, 06:15 PM | #4 |
Re: Halibrand 201
Might check with Hot Rod Works. Also, post the question on the HAMB,
10-23-2018, 06:24 PM | #5 |
Re: Halibrand 201
When I did mine I just used the bearing numbers and the local bearing shop.
10-23-2018, 06:58 PM | #6 |
Re: Halibrand 201
10-23-2018, 08:04 PM | #7 |
Re: Halibrand 201
10-23-2018, 08:29 PM | #8 |
Re: Halibrand 201
I have no issue with Hot Rod Works as I work with them from time to time. My comment was that I forgot to mention them for QC repairs, probably one of the best out there. Hope this clears this up???????
10-23-2018, 09:40 PM | #9 |
Re: Halibrand 201
Thanks, I believe I misread your post. Like I said, I have never used them but thought they had a good rep.
10-24-2018, 07:14 AM | #10 |
Re: Halibrand 201
Hot Rod Works is definitely good to work with. If they tell you something, you can bank on it.
Wayno
Life is not a spectator sport. |
