03-02-2014, 05:13 PM | #21 |
Re: Small leak in radiator and water pump
I rebuilt mine 5 years ago. Easy rebuild. Got my parts from Macs. I do have a press. If you do it be sure and measure where the pulleys sit on the shaft so your belts will line up again.
03-16-2014, 12:10 PM | #22 |
I got the bushings out using a kit I have for removing and installing bushings.
I took a closer look at the pulley today and found a crack. It doesn't look like it goes all the way through. Can I weld it? |
03-23-2014, 11:25 AM | #23 |
Is this metal cast iron?
09-02-2014, 01:45 AM | #24 |
Definitely can weld it. It is cast iron.
Grind out the crack and stick weld it with cast iron rod. |
Thread Tools | |
Display Modes | |
