09-07-2019, 04:55 PM | #1 |
Zenith Carb
I have several zenith carbs that I will never need. What are they worth
09-07-2019, 07:20 PM | #2 |
Re: Zenith Carb
From 0 to 2 or 3 hundred dollars depending on what shape there in.
09-07-2019, 07:51 PM | #3 |
Re: Zenith Carb
For reference - Bert's rebuilt Zenith Carbs that use flow tested jets and tested on an A, run about I believe $350 without a core. So as Fred says, depends on what condition, if they have been tested on a car, and what someone will pay for them.
09-07-2019, 08:44 PM | #4 |
Re: Zenith Carb
Do u have a zenith 3?
www.whidbeymodelaclub.com |
09-07-2019, 08:58 PM | #5 |
Re: Zenith Carb
I have Five of them.. Sorry about delay, I had to find them. Now I hope I get them to show up as I have had quite a few that doubt what I said I had..
09-08-2019, 01:22 AM | #6 |
Re: Zenith Carb
Steve |
09-08-2019, 09:53 AM | #7 |
Re: Zenith Carb
Zenith three carburetors are few and far between .
09-08-2019, 12:49 PM | #8 |
Re: Zenith Carb
Zenith 3 carbs used less cast iron than 1 or 2.
09-08-2019, 01:14 PM | #9 |
Re: Zenith Carb
how about a Holley? H on the upper half?
B carbs? |
09-08-2019, 02:44 PM | #10 |
Re: Zenith Carb
09-09-2019, 12:56 PM | #11 |
Re: Zenith Carb
Are these cores or re-built??
Paul in CT |
09-09-2019, 04:04 PM | #12 |
Re: Zenith Carb
Model B carburetors are thin and the upper flange is easily broken . I also have a couple of brazed upper model B carb housings .
09-10-2019, 07:20 PM | #13 |
Re: Zenith Carb
They are not rebuilt !
09-10-2019, 07:46 PM | #14 |
Re: Zenith Carb
I think I will keep all fifty of them, I thought that rebuilt sells for $ 350.00 with your core that these would be worth some money,my mistake
09-10-2019, 08:14 PM | #15 |
Re: Zenith Carb
there is a guy selling rebuilds for 170 on ebay. they go on ebay rough 50 nice may work by the look of it 100-125
09-11-2019, 02:00 PM | #16 |
Re: Zenith Carb
Pictures are posted of the Zenith # 3 Carbs..
09-11-2019, 03:00 PM | #17 |
Re: Zenith Carb
I think that Rex Reheis discovered several Zenith 3 carburetors sometime in the 90s . There was a write up in one of the national model A magazines about the carburetors and their discovery . A lot of model A guys , myself included had never seen or heard of a Zenith 3 at the time .I would consider them to be collectors items .
09-11-2019, 03:18 PM | #18 |
Re: Zenith Carb
I have seen one complete Upper/Lower and ONE and a half lower castings.
I say 1/2 because one lower casting was a Zenith 2 which someone used a Dremel in a feeble attempt to make the 2 into a 3 ... was sold on Ebay as I remember. Last edited by Benson; 09-13-2019 at 04:47 PM. Reason: correction 2 words removed one |
