03-30-2013, 05:32 PM | #41 |
Re: 59AB verses 59
I've got a 37-38 21 stud block without the frostplugs in the panrails. Yet another oddity....
03-30-2013, 07:04 PM | #42 | |
Re: 59AB verses 59
03-31-2013, 11:46 AM | #43 |
Re: 59AB verses 59
The history that we are always trying to unveil continues. On the 'Green' '37 21 stud engine, it must be Canadian...I live in Canada, and I do not see how it got over here from the US. But, having said that, this engine was re-built twice, and the last tag on the block indicated that a Ford Authorized re-building house did the job. Maybe they were bring in blocks from the US, as this past establishment was on miles away from the US border. I obtained this engine 25 + years ago and it came out of a '47 Coupe...the young lad gave up on this motor when he ordered the '47 gasket set and it did not fit the heads. Long story short, I obtained this unwanted 21 stud. Since it was all rebuilt with a .060 oversize, the engine had some potential. I installed this in my '34 Tudor, and someone finally convinced me to see it....car been in the corner garage for 22 years. Low & behold, the new owner did not like a 21 stud, and I purchased it back.....there has got to be 'something' about this engine...it's has to be destiny....and yep....I am going to give it a complete re-do for the '35 3W...Eddie Meyer heads and intake , twin 81's, etc...I guess even old flatheads get attached to their owners.
03-31-2013, 11:59 AM | #44 |
Re: 59AB verses 59
Hey, I was not finished....on the C59A....I decided to work on it and here is what I discovered. It has the freeze plugs on the oil pan rails, and notice the hear area water holes, a triangle, a round hole and a trapezoidal lower one. Let's say it's '40 block...must be Merc or truck at 3 3/16" stock bore. The cylinder walls are extra thick as can be seen and felt through the lower larger water hole. I always figured that this is one of those 'race wanted' blocks from Canada. Now for the slight shock...it has the tanged insert bearings and not the floating type....the connecting rods are marked 46 with the Ford script. This engine does not seem to have ever been re-built....but if not, this would be another great oddball, and as mentioned before, it passes the 'pencil test'.
The fun continues |
03-31-2013, 12:47 PM | #45 |
Re: 59AB verses 59
Just noticed something else different on this C59A block...the oil sender unit casting area is much larger than most. Also, it has the extra oil outlet whic is shown plugged. Maybe this has an interesting point....Robert
03-31-2013, 02:35 PM | #46 | |
Re: 59AB verses 59
clean fresh bore, new pistons ( installed ) with NO rings ?? main bearings good " new " rod bearing there but not right,, bad fit. ?? if someone got a grade on this, it should be "F" or D-...?? it was a gift...like U-haul, so I did. no history ? wish it could talk, ..like I wish my 39 fordor could talk. with a bullet hole in driver side read door. ?? OLD.....BILL |
03-31-2013, 06:35 PM | #47 |
Re: 59AB verses 59
Robert, your C59A would be post war Ford Canada, it's not unusual to find the insert type rod bearings in them from '46 on, and all Ford Canada blocks from about 1940 to the end of production had the inboard vertical oil passage drilled and tapped for Ford full flow oil filtering first used on wartime engines. It was optional from '46 to '51 on cars and trucks (and Mercs) but relatively few were sold so equipped. ..B.
03-31-2013, 08:12 PM | #48 |
Re: 59AB verses 59
Have 3 All 59 But different letters & numbers above 59. One is D91611 P second is E8733 11 third is H57? B8 Any info or comments appreciated. Kerk
04-01-2013, 01:56 PM | #49 |
Re: 59AB verses 59
Barlea.....thanks for the interesting input. I checked out other engines in my collection, and lo & behold, another similar one as the C59A. This one came from a truck with the double sheave pulleys, and it is marked 59A without the prefix C, other than that, all is the same including the drilled vertical oil passage. I checked other blocks, '49 & up, 8BA, 8RT, ECA, and all have the vertical oil passage feature. One can only conclude that with this oil passage and insert type bearings, it must be a later version using the casting from a different usage....very thick casting and passes the pencil test. Robert
04-01-2013, 03:36 PM | #50 |
Re: 59AB verses 59
Just to be sure, we are talking about two vertical and one horizontal oil ports on the Canadian blocks, and also it's not unusual to find a US block being rebuilt in Canada as some types of trucks came from the US plants as well as some low volume models such as wagons and convertibles. ..B.
04-01-2013, 05:15 PM | #51 | |
Re: 59AB verses 59
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" Last edited by Graeme / New Zealand; 04-01-2013 at 06:09 PM. |
04-02-2013, 09:54 PM | #52 |
Re: 59AB verses 59
59 vs 59A (59AB? & other 59 lettered) Blocks Ford USA
Enjoyed the contributions by all, especially the good pics since we can't poke & prod on-line. Upside Y 59 cool! Good Canada pics too. Still like to see clear picture of 59"A" stateside block. 59AB? Also other letter variants. 59L has been shown earlier --X? Z? others. & functional differences. See new Canada / Export engines Thread Need to file my taxes. Gene Tulsa |
04-03-2013, 09:33 AM | #53 |
Re: 59AB verses 59
Gene, you seem to be very keen on info and pics of these blocks....which is great. I wonder if anyone has ever documented the many different blocks, their numbering, and special features. You also mentioned on wanting a pic on a 221 59 block....here is one for you, picked up this block in Hershey, Pa. many years ago. Also, for a correction on my part, I did say that I had another similar block to my C59A, and that it did not have the C prefix...wrong, upon closer look, the C is partially there. See photo. I guess the C was not clear on the casting mold.
04-03-2013, 09:46 AM | #54 |
Re: 59AB verses 59
Oh yea, the photos. Here they are.
How about a '53 Merc engine ( late Ford with 255 engine ) ....heads are marked EAC ( upside down ) with 'Made in Canada' in a proper readable side. Would love for someone to document all of this with description and photos. Robert |
04-03-2013, 10:48 PM | #55 |
Re: 59AB verses 59
Robert Dip ,
Thanks for pics. Canada 59s are well identified as Canadian. What about pre war Canadian 21 stud, 24 stud 221 & 239? Are they clearly cast marked Canadian? USA post war 221ci (41A part #) replacement engine blocks are clearly mis-marked per "59" as 239ci.--as is yours. Canada post war 221s were correctly id'd as "51"---stated by others here--no pictures tho. Did your 221 "59" have all regular appearance features as 239 59s? Thanks Robert Gene Tulsa |
04-03-2013, 11:06 PM | #56 |
Re: 59AB verses 59
Since somebody asked, here's my 59 Z block. I haven't opened up yet, but expect to see that it is relieved. Both my 59 L blocks are relieved.
04-04-2013, 12:17 AM | #57 |
Re: 59AB verses 59
Thank you Southfork
What is the prefix on the SN#? Know what vehicle engine came from factory in? Eng/ trans combo original? Raining & cold here but beautiful day when we're having fun! Gene Tulsa |
04-04-2013, 09:43 AM | #58 |
Re: 59AB verses 59
G32 "Did your 221 "59" have all regular appearance features as 239 59s?"
Yes, 100%..does not pass pencil test, no frost plugs in oil pan rails, etc. This engine has a re-build tag, but pistons are N-STD Robert |
04-04-2013, 05:39 PM | #59 |
Re: 59AB verses 59
I have no idea what the 59 Z came out of. I got it from the estate of an ol Ford restorer. He also had one of the 59 L's that I now have and also one of those pre-war 239's.
04-04-2013, 06:05 PM | #60 |
Re: 59AB verses 59
I have a 59 Z block that I just rebuilt. It was a postwar 221 replacement block for the wore out 221 engines. This one came out of a 1939 farm truck. Nice blocks. Ed
Thread Tools | |
Display Modes | |
