11-11-2019, 03:19 PM | #1 |
Water Glass
Anybody else used "water Glass" (Sodium Silicate) on a cracked block in the old days?
11-11-2019, 03:45 PM | #2 |
Re: Water Glass
Yes. Some stop leaks today contain water glass. All depends on the crack.
11-11-2019, 03:52 PM | #3 |
Re: Water Glass
I’ve used it years ago on my Buick Riviera and it works well but eventually the water pump bearing became rough and loose. I think when it gets past the seals on a modern water pump it ruins the bearing.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
11-11-2019, 06:17 PM | #4 |
Re: Water Glass
I've used it for the passed 50 years with success on all but one engine. I've never had to use it on a model a or t engine. I never have had water pump trouble that I could tell. Used it on heavy equipment engines.
11-11-2019, 07:11 PM | #5 |
Re: Water Glass
I was not impressed with the stuff. On my fresh engine rebuild one head stud/nut weeped a bit. An old timer in the club insisted I use water glass. I flushed the cooling system for months as it kept clogging up the cooling system. Not a fan of this stuff.
11-11-2019, 07:39 PM | #6 |
Re: Water Glass
I know the voices aren't real but damn they have some good ideas! |
11-13-2019, 10:26 AM | #7 |
Re: Water Glass
I used water glass in my '37 Pontiac coupe. It would work for well for about a month and then I would have to add some more water glass. When it leaked, the water would go out of the exhaust. I drove the coupe for about two years, then I sold it to the junk yard for $25. Black pepper also worked well as a stop leak for me. This was in 1957.
11-13-2019, 12:10 PM | #8 |
Re: Water Glass
Yes but a stitch repair is better, depending on where the crack is.
