01-29-2020, 10:49 AM | #1 |
replacing window glass 37 Woodie
Right side front window broken. I have taken the broken glass out, and opened the wood paneling. It has the riser glued to the window. If this is how it was originally secured? How is the riser held to the new glass. Is it glued? I assume a good glass person will know but want to understand what was done originally. Thanks for any help. Pete
01-29-2020, 12:24 PM | #2 |
Re: replacing window glass 37 Woodie
It was a press fit originally with a rubber channel along the lower edge of the glass, not glued.
01-29-2020, 04:21 PM | #3 |
The new glass is set within "glass setting tape" and then pressed in to the track.
