11-04-2018, 04:38 PM | #1 |
Flathead On Engine Stand
Does the exhaust type stand adapter and its bolts safely support the weight of a full dressed flathead? Anybody have problems with this set up?
11-04-2018, 04:42 PM | #2 |
Re: Flathead On Engine Stand
Yes, that's probably the best way . The entire engine can be built except for the one exhaust manifold.
11-04-2018, 07:36 PM | #3 |
Yes, that is the best approach. On a 58ba it is not really an issue, but on the earlier blocks with the integral half bellhousing it is.
11-04-2018, 08:04 PM | #4 |
An 8BA can hold the full weight of complete engine using bellhousing.
Do not use a 3 legged engine stand. It must have have 4 casters. I removed some parts to do some work on it Full engine was there at the start. Last edited by 19Fordy; 11-04-2018 at 08:39 PM. |
11-06-2018, 02:45 PM | #5 |
Why not a three leg
11-06-2018, 03:09 PM | #6 |
11-06-2018, 04:34 PM | #7 |
The three leg stand issue is not specific to flatheads, any engine is unstable when using them.
11-06-2018, 05:30 PM | #8 | |
11-06-2018, 06:26 PM | #9 |
They must have printed the picture backwards and then wrote on it....I like the price!!!...Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
11-06-2018, 07:30 PM | #10 |
Speaking of Flatty engine stands; it seems to be getting very hard to find someone that makes these adapters or the "cradle like" brackets for flatheads, the one vendor "stumpy's fab works" seems to be non responsive and vern tardell seems to be out of them too, anyone know of vendors that make the side adapters or stands?
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
11-06-2018, 07:32 PM | #11 |
That's all I have is 3 legged ones. Never had an issue before with up to a Ford 460 on them. That's probably double what a flathead weighs.
11-06-2018, 08:05 PM | #12 | |
(804) 245-1959 Cheers Tony |
11-06-2018, 10:05 PM | #13 |
Some of us here have welded a piece of angle iron about 20" long onto the plate that comes with the engine stand. The 'legs' of the angle are welded to the plate so the 45 degree face is where you bolt the engine. I just set an exhaust manifold on the angle before welding and drilled through the holes. No machine work, no math. It's great that these V8s are built at a 45 degree angle. If you don't weld, I bet a local shop would do it for a very small fee if you had the metal drilled, paint sanded off etc. I checked into the adapters and 65 bucks or so.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-06-2018, 10:46 PM | #14 |
Yes, that is the ultra, ultra rare 8BA prototype engine. It is the only one made by "misprinting" the negative. I never noticed that photo error before after all these years. I still have the engine but, now it's "normal". Thanks for noticing.
11-06-2018, 11:13 PM | #15 | |
Are you old enough to remember the old guy on a tricycle on Rowan and Martin's 'Laugh in'?
11-06-2018, 11:14 PM | #16 |
Never ever had a problem with 3 legged stand. But I do not go off road with it
11-06-2018, 11:26 PM | #17 |
Speaking of three legged stands https://www.youtube.com/watch?v=QQh56geU0X8
11-07-2018, 11:39 AM | #18 |
The much aligned Harbor Freight sells a motor stand that works very well. It is reasonable price, probably china made.( I gave up not buying made China stuff ) It has 2 wide legs and 2 not so wide ones in front. I made a exhaust attachment for it but used to hang 35-36 blocks by the bell housing with no problem. Even hauled a couple to the rebuilder 20 miles over not so smooth road.
11-07-2018, 12:55 PM | #19 |
Regarding the side mount adaptors, Specialty Ford in Rosemead, California has them. 626 288 2121.
Wayno
Life is not a spectator sport. |
11-07-2018, 03:23 PM | #20 |
Yup. I hung a complete 354 HEMI on one HF stand. Supported the front of the engine
with two 2 x4's and a 2x6 straddling the legs just to be safe. I know it's not a flatty but, one must admit it's pretty. |
Thread Tools | |
Display Modes | |
