02-07-2019, 09:02 AM | #21 |
Re: Is fuel bubbling normal
If its not vapor locking I wouldn't worry about it. Will it start up after sitting for a half-hour or so ?
02-07-2019, 09:38 AM | #22 |
I am not so sure we are being 100% accurate in our comments above. To begin with, ethanol has a boiling point of just a tad under 175° (-not 147) and gasoline itself has a boiling point of about 200°, ...and more to the point is unless someone is running E85 fuel, there is only 10% ethanol fuel mixed in gasoline. Therefore that amount of ethanol is not that big of a deal when 90% of it is gasolene.
Second, folks get all 'excited' about underhood temps claiming it affects ethanol fuels, ---and while it can, most tend to overlook a riding lawnmower in the middle of July cutting tall grass. The stagnate underhood temps of that lawnmower likely exceed what we encounter with a Model-A, and yet we never hear of lawnmowers having percolation issues. My vote is there is an issue outside of the fuel itself that is creating the problem(s). . |
02-07-2019, 10:26 AM | #23 |
Good Morning all...Here in the southwest, many of us run Marvel Mystery Oil in our fuel. It has been around for many years and most hardware and auto parts stores carry it. It takes four ounces in 20 gallons or 2 ounces in 10 gallons to lubricate valve stems and to help stabilize fuel in hot weather. Good Stuff and not expensive. I use it in our 31 Model A and our 49 Packard and they both like it. Ernie in Arizona
02-07-2019, 10:31 AM | #24 |
I also use MMO in the gas on all my classic cars. But I do mix it as recommended on the bottle, which is 4 0z per 10 gallons.
02-07-2019, 10:40 AM | #25 | ||
02-09-2019, 10:35 AM | #26 |
02-09-2019, 11:09 AM | #27 | |
How warm is the plastic filter? If the plastic filter is not hot, I would venture the bubbling has something to do with fuel flow from the tank or back from the carb! Not sure, but if the fuel filter is not warm or you can put your hand around it and it is just warm, the fuel in it certainly is not boiling! It may be bubbling because of fuel flow with air in it but????? As a test, I would suggest removing the inline filter, replace with a piece of copper tubing the same size and see if the bubbling moves to OEM glass sediment bowl. If it does still bubble, provide some feedback either way to those following this post. |
02-09-2019, 12:38 PM | #28 | |
If you bought an inexpensive IR Temp gun, be aware it may not work by going nuts when the motor is on. Inexpensive ones are sensitive to the Model As electrical noise generated by ignition/sparking. In extreme cases the gun is damaged. |
02-09-2019, 02:45 PM | #29 | |
02-09-2019, 02:47 PM | #30 |
Good to know. I bought the $26.00 one at Harbor Freight. Should read close enough for what I need but I will have the engine shut down before using it. Thanks for the heads up.
02-09-2019, 03:17 PM | #31 |
Other tips.
Best to do it in the shade or in the garage in low light, the led pointer is very difficult to see in high light situations. You can check accuracy by bringing water in a pan to a good boil, measure the water, should be around 212 F, dependent on what altitude you are. Another nice measurement is after driving for a while measure the brake hubs, if one is warmer/hotter than the others, it might be dragging, or possible bearing issue. With Motor running measure each radiator tube in a horizibnal line across the radiator. If one or more are quite a bit cooler, you have a blockage. Repeat at different heights on the radiator. Measure the radiator inlet neck and outlet neck to see the coolant differential. Measure the head on the head at the base of the spark plugs, all should be close Measure the Block horizontally across on the driver side, if one area is a lot hotter possible rust scale in a water jacket (typically cylinder 4). Record your readings, gives you a reference for future troubleshooting. All kinds of fun things to measure. |
02-09-2019, 06:12 PM | #32 |
Rusty Karz states the vehicle is a 1931 Tudor but he does not give us the insight of whether it is an early 1931 which would have a firewall sediment bowl or a late 1931 which would have the fuel line feed into an iron sediment bowl screwed into the carburetor. If it is the late 1931 perhaps there is no filter at the carburetor, and the in line filter is a substitute and is the cause of the problem. Cause of the problem or not it is a fire hazard.
02-09-2019, 06:27 PM | #33 | |
I remember the Christmas bubbling lights that had a little vial containing an alcohol mixture warmed over its light bulb. It didn't take much heat to make it the liquid bubble. Your fuel line is showing the same results. Go to steel lines and it won't bother you, because you won't be able to see the bubbling. |
02-10-2019, 09:31 AM | #34 | |
02-10-2019, 10:52 AM | #35 | |
02-11-2019, 09:04 AM | #36 |
I have shut down my car before and heard boiling coming from the carb but it never seems to stop it from running.
02-11-2019, 11:15 AM | #37 |
The late '31 Model A with the fuel shut off on the engine side of the firewall should have it's cast iron sediment bowl correctly attached to the carburetor. It is unique.
