10-01-2019, 09:59 AM | #1 |
Mallory Ignition
I have a Mallory Distributor, Type 11A, Model YCM that has dual points and centrifugal advance. What engines does this fit?
Bob Bidonde |
10-01-2019, 11:57 AM | #2 |
Re: Mallory Ignition
That distributor fits both model A and B engines . I have two of those Mallory distributors and love them . Dual points is said to double the spark . My girls especially like the Mallory distributors because they don't have to worry with the spark lever . The last Mallory distributor that I bought was probably around 96 or 7 and it has performed flawlessly . The only thing that I ever had to replace is the condenser . I've been told by a reliable source that Mallory has been sold and the newest Mallory distributors are not nearly as good as they use to be .
10-01-2019, 06:03 PM | #3 |
Some of the old Gleaner combine engines were model a power units. The ones that I've encountered that were used in this area had Mallory distributors with dual points. I have one but never have used it.
10-01-2019, 06:26 PM | #4 |
The Y is mechanical advance only. The M is for Magspark.
And the C means it has the Magspark guts (may some breakers and a special cam??). |
10-02-2019, 11:35 AM | #5 |
Dual points will add to the capability of increasing the spark, but in reality won't change the way the engine runs as it uses only what it needs. 4 cyl. engines have plenty of dwell time with one set of points, and all that dual points do is increase dwell time.
10-02-2019, 12:04 PM | #6 |
Thread Tools | |
Display Modes | |
