Old 04-29-2019, 01:03 PM   #1
chrs1961815
chrs1961815's Avatar
Default Rumble Lock Trouble
After posting about this a while back, I fixed the problem by realizing that I had installed the handle incorrectly. But now it won't lock again. The key just turns really smoothly in the lock - no resistance. Is it the handle installation or is it the mechanism itself?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-29-2019, 03:39 PM   #2
jw hash
jw hash's Avatar
Default Re: Rumble Lock Trouble
depending on what handle you have, it sound like the little tit that is on the end of the tumbler is broke off. they will do that.
jw hash is offline   Reply With Quote
Old 04-29-2019, 04:44 PM   #3
chrs1961815
Just a regular rumble handle.
Old 04-30-2019, 01:09 PM   #4
chrs1961815
A new handle should fix it?
Old 04-30-2019, 03:05 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
Take the handle off, look at the latch, there should be 2 notches, then look at the handle, operate the key and see if the locking pin moves out and stays, I have seen the notches in the latch broke off
Old 04-30-2019, 03:50 PM   #6
chrs1961815
This is what it looks like:
Old 05-01-2019, 06:35 PM   #7
chrs1961815
Just was looking and realized there was no nut on the end of the bolt on the driver's side rumble hinge. Took the whole rumble seat out and I am replacing the bumpers and new hardware all around. I want to take out the lock mechanism, how do I do that?
Old 05-01-2019, 06:42 PM   #8
jw hash
jw hash's Avatar
there is two screws on the edge of the lid right next to where the latch swing out. and the latch will slide right out.
Old 05-01-2019, 07:07 PM   #9
chrs1961815
I took those two screws out and it hasn't budged. Almost looks too big to come out.
Old 05-01-2019, 07:11 PM   #10
chrs1961815
Also, which way do the lower bumpers go? They were like this.
Old 05-06-2019, 10:08 PM   #11
chrs1961815
Update: replaced the handle and the mechanism. Although tighter, it still does not lock. What else could be the problem?
Old 05-07-2019, 07:38 AM   #12
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
Did you check that the latch (hook) is thin enough to slide into the slot mounted on the cross member at the top. I had one that was too thick and wouldn't go in the slot.
MickeyT is offline   Reply With Quote
Old 05-07-2019, 07:41 AM   #13
chrs1961815
It is thin enough. It will turn but not lock. I am puzzled.
Old 05-07-2019, 07:55 AM   #14
Tim Ayers
On my '28, I bought an A/M latch piece that mounts the body. Even with filing the opening, it would not allow the paw to engage. Found a real Ford one, works perfectly.
Look from the top through the body opening to make sure it is clearing the catch on the body side.
