Old 09-25-2019, 01:04 PM   #1
TradModelA
Default 6 volt coil wiring
I have 41 ford with helmet style distributor, external coil conversion. This is positive ground so which wire goes to the coil is it negative from switch and positive to the distributor?
TradModelA is offline   Reply With Quote
Old 09-25-2019, 01:16 PM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: 6 volt coil wiring
The distributor completes the circuit by going to ground when the points close, so it's the positive wire.
4dFord/SC is offline   Reply With Quote
Old 09-25-2019, 02:14 PM   #3
JSeery
JSeery's Avatar
Yes. Wire from ignition switch to (-) terminal on the coil. (+) terminal on the coil to the distributor (points). The condenser is also somewhere in the circuit from the (+) terminal on the coil to the points in the distributor.
