03-15-2020, 10:12 PM | #1 |
U-Joint Inner Cover
I should probably know this but I don't! Which way do the two holes in the inner U-joint cover go? Up and down.... Side to side??? Don't matter..And why? Are they a means for grease? What is their purpose? I'm so confused....
03-16-2020, 01:14 AM | #2 |
Re: U-Joint Inner Cover
I think you will find it will only go one or two ways,both right.
Lawrie |
03-16-2020, 08:27 AM | #3 |
The holes are to allow grease oil to flow from the grease fitting into the inter cavity.
03-16-2020, 08:35 AM | #4 |
side to side
03-16-2020, 09:11 AM | #5 |
Thank ya'all for the help, I knew I had two choices.....LOL
Side to side it will be... let the grease flow |
03-16-2020, 12:35 PM | #6 |
