08-28-2018, 07:53 AM | #1 |
Very Early 1930 vehicles...
For those of you who have a VERY early car, one assembled from December 1929 thru March 1930, how many have a pocket hole on each side of the frame for the NEW STYLE Emergency Brake Cross Shaft which by the way would be added in April 1930?
Thanks. Pluck |
08-28-2018, 10:44 PM | #2 |
Re: Very Early 1930 vehicles...
Does that include Canadian cars?
08-28-2018, 11:07 PM | #3 |
08-29-2018, 01:06 PM | #4 |
my January 1930 cabriolet has the holes, plugged.
08-29-2018, 06:58 PM | #5 |
Pluck,
I know how we can tell when the engine was produced...how can we tell when the car was assembled? Thanks.
All steel from pedal to wheel |
08-29-2018, 10:37 PM | #6 | |
Pluck |
08-31-2018, 12:37 PM | #7 |
Steve, I believe my coupe is very early 30, but I don't know what to look for.
What's the difference between old and new? Pocket holes? |
08-31-2018, 12:49 PM | #8 |
My friends Canadian coupe is # 156 from the Ontario plant. It has the long cowl band. It has the late emergency brake in it, so who knows.
08-31-2018, 05:43 PM | #9 | |
Even if I knew how to get the Assembly Plant Sales Slip (I don't), the body number doesn't cross to a known assembly plant (at least one that I know of). The only "R" is Richmond, CA, but that plant opened well after my car was assembled. I believe mine was assembled in Milwaukee since it has been a Wisconsin car up until my purchase of it, but it looks like the Milwaukee plant has an unknown alpha character associated with it.
08-31-2018, 09:04 PM | #10 | |
Maybe this will help you??? http://www.plucks329s.org/pdf/studie...20Part%201.pdf View page 449 in the April 1930 Ford Service Bulletin for the "pockets" on the side of the frame. Pluck |
09-08-2018, 01:43 PM | #11 |
According to your notes on frame evolution, my car's frame is post-1/3/30, no holes for RHD. The e-brake cross shaft passes through the side rails, so I assume it's the later part.
https://www.modelagarage.com/service...e-cross-shaft/ (Fig. 884) Interestingly, the engine # A1812126 dates to late June 1929. I spoke to the guy who did the body-off restore in 1989, and he assures me the frame # matches. That engine must have sat on the bottom of the stack for quite a while. |
