Old 03-10-2021, 11:15 AM   #1
BillW810
BillW810's Avatar
Default 1939 Ford Deluxe hood hinge mounts
0I couldn't get a pic in PM. Here is the part I'm talking about.
BillW810 is offline   Reply With Quote
Old 03-10-2021, 04:18 PM   #2
BillW810
BillW810's Avatar
Default 1939 Ford hinge mounts
I know doubtful but if you don't ask.
Anyone have either these two or these 2 connected to the cross brace? Hood hinge mounts 1939 Ford Deluxe. I found a whole hood but shipping is proving to be difficult.
Old 03-11-2021, 10:04 AM   #3
Pete pa
Default Re: 1939 Ford Deluxe hood hinge mounts
Remove the entire brace from the hood straighten it install new tee nuts for the hinge bolts if needed and weld it back in. That is repairable, if you need pictures of what that should look like let me know.
Pete pa is offline   Reply With Quote
Old 03-11-2021, 10:19 AM   #4
Ken hash
Ken hash's Avatar
I think Pete has the right idea. This can be repaired. You really have nothing to lose by trying. Good luck
Ken hash is offline   Reply With Quote
Old 03-11-2021, 11:11 AM   #5
BillW810
BillW810's Avatar
That is the plan going forward thanks. The T nuts I found are smaller OD than the mounting hole in the hinge. I found some 1/2 OD tubing I guess just make a boshing. There will be a little slop because the ID of the TUBING us larger than the OD of the t nut. In the scheme of thins I guess not much.
Bill
Old 03-11-2021, 11:16 AM   #6
Karl Wescott
Karl Wescott's Avatar
you could use a 5/16 - 18 tee nut, that will have the correct barrel size for the hinge. The only issue then (if it matters) is the bolt is oversize from true original.
Karl Wescott is offline   Reply With Quote
Old 03-11-2021, 01:16 PM   #7
BillW810
BillW810's Avatar
I have no problem with that I didn't think of it.
Thanks!!
Bill
Old 03-11-2021, 04:46 PM   #8
mercman from oz
mercman from oz's Avatar
Does this picture of the Hinges on a 1939 Ford Deluxe help?
Old 03-11-2021, 05:27 PM   #9
BillW810
BillW810's Avatar
Very much so. I was going to ask if the mounts should be flat against the hood. Mine and the ones in a hood I was looking at are not flat against the hood. Buying that other hood would not have helped.
Are they shoulder screws on both ends of the hood support.
Thanks!!
Bill
